DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
method on fitting plain skirting board
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
  View previous topic :: View next topic
Author Message
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 8:29 pm    Post Subject:
Reply with quote Thanks
Hi, i need to fit new skirting board after fitting wood engineered flooring, i have purchased the skirt and a mitre box. I have never fitted skirting board before and i dont want to make a mess as the skirting is the last part of my job. I only have two corners to cut (internal)i just need to know the method in what order to do it . Ie the measuring and cutting . Any tips would be apreciated .Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dextrous
from United Kingdom
Thanked: 49 times
PostPosted: Fri Jul 03, 2009 11:08 pm    Post Subject:
Fix one skirting in place full length. Mitre off the joining end of the next piece, and use a coping saw to cut along the (curved?) profile now showing on the face side. This allows for the walls not being perfect;y square and give a margin of error. Depending on if the skirting is to be finished au-naturale or painted, you can sand or trim this to make as perfect a finish as possible, or use a bit of decorators caulk to fill the gap prior to painting (if you are painting, I'd recommend you put the knotting and primer on and let it dry before cutting the timber - one less chance of marking the floor with erroneous paint). Put into place, possibly set a few mm parallel to the wall if you're running up to an architrave, mark and cut exactly to length.
__________________
A rolling stone gathers no moss.
Back to top
 Alert Moderators
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 5:55 am    Post Subject:
Will follow your tip ,Thanks
Back to top
 Alert Moderators
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 9:39 am    Post Subject:
Thanks again for the advice ,room now finished ,only scrapped one piece....... came in handy though to practice on.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Method for fixing skirting over hard floor.... 5 220 Mon Aug 03, 2009 11:41 pm
Construction method 2 440 Wed Aug 15, 2007 12:23 am
Best method to screw onto top of cabinet? 5 640 Sat Aug 25, 2007 4:39 pm
Jointing method. 2 300 Sun Jan 25, 2009 9:13 pm
Fitting skirting board 3 620 Tue Sep 04, 2007 9:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
