DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Kitchen Worktop Mitre Joint
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
  View previous topic :: View next topic
Author Message
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 12:14 pm    Post Subject:
Reply with quote Thanks
Planning to use a mitre to join corner of worktops. Is there any tip that I need to make sure I get it right
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
vitalchip
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 3:30 pm    Post Subject:
Make sure you've got a sharp cutter and that the jig is firmly clamped down. Take a number of shallow passes ( about 6mm each ) holding the guide firmly against the back face of the slot in the jig. Once you're all the way through make one full depth pass holding the guide firmly against the front edge of the slot.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Sat Jul 04, 2009 4:30 pm    Post Subject:
Re: Kitchen Worktop Mitre Joint
I think you will have more success with a butt and scribe joint.
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 8:04 pm    Post Subject:
I have seen somewhere that at times they supply biscuit joints for the mitre cuts. How do we use these and what parts is required for this.
Back to top
 Alert Moderators
vitalchip
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 04, 2009 8:16 pm    Post Subject:
I assumed you meant a masons mitre.. you're not planning to try cuttong a regular 45˚mitre are you?
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 05, 2009 3:54 pm    Post Subject:
Yes, it is a mason's mitre. I was thinking of inserting a biscuit wedge on either side of the cut to keep both worktops at the same level when tightening the bolts underneath. Is that advisable / practical.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
kitchen worktop joint blown 8 460 Mon May 19, 2008 10:34 am
Help required! Cutting through a worktop joint 5 1820 Thu Feb 15, 2007 4:56 pm
Adjusting worktop joint after Colorfill is set? 5 420 Tue May 13, 2008 9:58 pm
Sink in the way of worktop joint 6 760 Fri Jun 11, 2004 2:38 am
POLL! biscuits in worktop joint 14 1080 Sun Oct 03, 2004 11:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
