garlicbread
Joined: 24 Jun 2008 Posts: 16 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Sat Jul 04, 2009 12:22 pm Post Subject: IT radial circuit |
can anyone tell me with regards to a radial circuit which will have IT equipment on it, what do you do with the last socket regarding the cpc, obviously on a ring all sockets will have 2 separate cpc's to terminate in separate earting terminals, but what about the last socket on a radial. Is it just a case of linking them.
also im struggling to find out the correct procedure when it comes to earthing galv steel back boxes. if there is a fixed lug on the back box, is a link between socket and back box not required? Struggling to find anything in the regs
cheers |
Adam_151
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
garlicbread
Posted: Sat Jul 04, 2009 12:33 pm Post Subject: |
yeah just 1 No radial |
Adam_151
Posted: Sat Jul 04, 2009 12:53 pm Post Subject: |
In that case, you'll need a separate earth wire from the DB (minimum size 4mm˛), if its a circuit for something like a data cabinet, take the 4mm˛ earth through the FCU, but dont terminate it there, have it come out and follow the flex to the cabinet and have it bolted to an ECP on the equipment. If its for a socket outlet circuit, then take it to the last socket so that the cpc is effectivly a ring, and do as you would on a ring; use separate terminals |
garlicbread
Posted: Sat Jul 04, 2009 12:55 pm Post Subject: |
cheers thanks for the info |
Chri5
Joined: 19 Jan 2007 Posts: 1827 Location: London, United Kingdom Thanked: 28 times
Posted: Sat Jul 04, 2009 12:56 pm Post Subject: |
Standard radial without high integrity earthing (seperate CPC in addition to the one in TE).
Last socket will just have the 1 x CPC, the sockets may have 2 x earth terminals but they WILL link via metalwork manufactured in to the socket.
Good practice is to have a earth 'strapper' cable between the metal back box earth terminal and the socket in ADDITION to the earth that connects via the box -> fixed lug -> screw.
It's a better earthing method and although unlikely, the screw making the earth could become loose, rust, break or be changed for a nylon screw. |
