have a vaillant combi, recently turn hot water tap and boiler wont turn on until a second tap is opened, checked pessure which is at 2 bar (1 bar normally), ch is working fine, oiler is 3 years old and serviced every year
this morning the boilker wont fire up at all when water taps are open, ch is still fine. its a vailant 282/1e and this problem only occurred a few days ago
Release some water out of your system (drain valve ) to get the pressure back to down to 1 bar. If the pressure keeps going back up you will need a heating engineer. Your problem could be a faulty flow switch not sensing the change in pressure when you open your hot tap.
Not a diy job and you will have to call in a Corgi
