Hi there,
Wondering if someone could help me out here. Would be most appreciated!
I have now for a long time been struggling with my boiler. Since I ve moved in the house, the hot water could never continuously flow i.e. when having a shower, you would get hot water for about 5minutes then lose it and then get it again.
I have called various people to come and fix the problem. One of the guys recommended that i get a power flush, to clear the system of small debris. He pumped the system with a chemical, through the radiators, etc but note that he did not remove the boiler itself and clear the actual boiler (as I have been told this is the proper way to do it). This did not solve the problem!
He then went onto to say it could only be the ?heat exchange filter? that is faulty.
I went to call another guy, and he said the heat exchange filter could not be faulty without me noticing (somehow). He recommends i change my boiler altogether!!!
I would greatly appreciate if someone could help me out on this and give me some much needed advice.
Cheers,
Ian
(no knowledge of boilers whatsoever)
Cheers,
Ian
