Joined: 09 Apr 2005 Posts: 452 Location: Cleveland, United Kingdom Thanked: 6 times
Posted: Sun Jul 12, 2009 9:17 pm Post Subject:
8mm couplings
Hi all
I am moving a rad in the morning which is on 8mm pipe. I need to cut & join the said 8mm pipe, to save getting 8mm couplings will a section of 10mm pipe do instead the bore seems just over 8.5mm??
Thanks in advance.
JonB
Hi all
Thanks in advance.
JonB
Posted: Mon Jul 13, 2009 3:53 am Post Subject:
I was not going to buy any 10mm pipe I have 6ft laid in the garage. 8mm couplings dont seem to be readily available, Its not a question of being tight. Thanks to all the smart Alec's.
Posted: Mon Jul 13, 2009 2:23 pm Post Subject:
Thanks for looking dex, but I didnt see any 8mm at ?crewfix.
Anyway when I took the boards up there was enough movement in the pipes to move the rad 7.5inches. So no drain down & I can return the freezing kit back for a refund.
Thanks again
JonB
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
