Indesit WIXL126 washing machine flashing lights
12 Jul 2009
Somerset
Two green lights and red door light flashing!!
Does anyone have key to error light codes?
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Many thanks
Flashing lights are 1and 2 plus door light
Anything can be done DIY?
Cheers
that code is f12 com error ,unplug the plug connections on the pcb and refit . if that dont work a exchange pcb is required from emw.
Can any one hel i have the F09 but not sure what it means and relly would like help thanks
f16 N/A
It means the chip is corrupt new Pcb needed nothing you can do.
f16 N/A
I have the F03 fault - can you please tell me what an ntc fault is?
Thank you.
Ntc is on the heater , with 2 thin wires on it but it is most prob be a pcb fault.
