DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Indesit Dishwasher IDL 530 - Error Codes
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
ClareP
from United Kingdom
PostPosted: Thu Jul 16, 2009 8:14 am Reply with quote
HI,
D/W is just over 12 months old! and the 2nd and 4th lights from the left both start flashing about 3/4 way through the programme and the cycle stops.
Any ideas anyone?
Thanks,
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1005 times
PostPosted: Thu Jul 16, 2009 12:24 pm Reply with quote
Led 1= Prewash / 3hr
Led 2= Wash / 6hr
Led 3= Rinses / 9 hr
Led 4= Drying / 12hr
LED. illuminated
1 = Overflow ( water in base )
1+2 = Pump timeout, or Software recognition error ( timer not programmed, wrong keypad)
1+3 = Circulation pump not working
2+3 = Not filling
2+4 = Heating circuit not working
2 = Solenoid valve 'broken'
3 = Thermistor (NTC) cicuit not working
4 = Temp not reached whilst heating ( poss NTC detached from casing).
It is usually necessary to 'reset' the machine after a fault code has been displayed.
Resetting.
Switch dishwasher OFF, rotate the selector switch to STOP/CHANGE and switch on, after a few seconds the LEDS will go out enabling a new programme to be selected
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Thu Jul 16, 2009 12:27 pm Reply with quote
check that the thermister is attacted to the door, remove front panel and there should be a white clip on the rear of dispenser.if thats ok turn rinse aid down to 1 .and dont use 3 in 1 tabs and rinse aid and salt it causes it to overfoam in the heater.just use 3 in 1 on its own .
Back to top
 Alert Moderators
Dishdoc
from Netherlands
PostPosted: Mon Nov 02, 2009 10:08 am Reply with quote
We have a IDL 42, which stopped working. Led 1 flashes, which seems to mean that we have 'water in base'.
How can I fix this? Anyone ideas?
(rocks1?)
Thanks.
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Mon Nov 02, 2009 2:38 pm Reply with quote
tip mc back does water come out if so you have a leak ,poss from bottom spray arm nut or loose salt pot .
Back to top
 Alert Moderators
Dishdoc
from Netherlands
PostPosted: Tue Nov 03, 2009 12:49 pm Reply with quote
Water does in deed leak out when tipping it backward. I will try to find out whether it is due to the spray arm or salt pot.
Do you know how I can best approach that area?
Thanks again!
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Tue Nov 03, 2009 3:10 pm Reply with quote
see if they are loose ,if not remove the base put dishwasher on a block of wood shine torch underneath to see where the leak is .
Back to top
 Alert Moderators
Dishdoc
from Netherlands
PostPosted: Sat Jan 02, 2010 12:07 pm Reply with quote
last posts have been very helpful. Found the leak and was able to fix it.
Now the last light flashes (nr 4), which means that:
'Temp not reached whilst heating ( poss NTC detached from casing)'
Somehow the machine showed this problem a little while ago, but especially while using washing program nr1. Now as well with washing program nr3.
Do you have any idea how to approach this problem? And what exactly is the NTC?
Thanks for your time and advise!
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Sat Jan 02, 2010 1:05 pm Reply with quote
remove door panel ntc is attatched to the rear off dispenser a little white thing with 2 black wires on it refit to the clip on the dispenser.
Back to top
 Alert Moderators
zarni
from United Kingdom
PostPosted: Sun Jan 10, 2010 12:02 pm Reply with quote
Led 2= Wash / 6hr
LED. illuminated
2+3 = Not filling
Resetting.
I have an IDL 705, originally was tripping main circuit due to a leak, now fixed. how ever on restarting the DW lights 1 and 3 flash (presume = circulation pump??) is there an easy fix? or will i need to replace pump?
generally how much would it cost to get a service engineer in to do it?
Thanx for any advice
Zarni
Back to top
 Alert Moderators
Dishdoc
from Netherlands
PostPosted: Sun Jan 24, 2010 9:47 pm Reply with quote
Identified the NTC finally. Tried to refit it (still seems a bit loose). Do I need to get some of the white paste to increase contact?
The 4th LED still flashes whatever I tried until now. Do NTC's wear out or stop working some time? Or is it just the attachment?
Kind regards.
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Sun Jan 24, 2010 10:33 pm Reply with quote
bend the metal strip that holds it in and tighen the screw or put a blob of glue to hold it in .
Back to top
 Alert Moderators
liquidimagenick
from United Kingdom
PostPosted: Sat Oct 16, 2010 6:54 pm Reply with quote
Led 2= Wash / 6hr
LED. illuminated
2+3 = Not filling
Resetting.
Hi there,
Hopefully you can help me with mine ? The 2nd & 4th are flashing which thanks to your guide says that it is the Heating circuit. But how would you recommend I go about trying to fix this myself?
Any help would be very much appreciated.
Thanks Nick
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Sat Oct 16, 2010 6:59 pm Reply with quote
Yes heater is faulty but check it with a meter just to be sure
Back to top
 Alert Moderators
liquidimagenick
from United Kingdom
PostPosted: Sat Oct 16, 2010 7:21 pm Reply with quote
Thanks, what roughly should it be reading?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Indesit DI450 Slimline Integrated Dishwasher Error Codes 5 1780 Wed Dec 23, 2009 6:09 pm
Indesit Dishwasher d41 error codes 7 8000 Wed Dec 27, 2006 8:20 pm
Indesit IDL530 Dishwasher - Error Codes Please 6 4740 Sun May 24, 2009 11:02 am
Indesit Error Messages and Error Codes 4 1660 Wed Jan 14, 2009 12:34 pm
indesit ariston error codes 4 3920 Wed Jan 14, 2009 3:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
