DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric oven
  View previous topic :: View next topic
Author Message
Master of None
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jul 19, 2009 3:45 pm    Post Subject:
Electric oven
Reply with quote Thanks
I am thinking of purchasing an AEG oven Model B996985M Link to data sheet below.
http://www.aeg-electrolux.co.uk/Files/united_kingdom_english/AEGCategoryImages/BI%20Specification%20Tables.pdf
While it clearly states 13A. Does this mean it will come or can be fitted with a normal 13A plug on it at a stated 3.1KW.?
The reason I ask is that my kitchen currently has a 32A 6mm2 dedicated radial for an induction hob switched above worktop. But only 13A fused DP switch spurred off the kitchen ring connected to a dedicated 13A single socket in the unit beside oven location.
I am going to call them tomorrow but wondered if I need to look at alternatives.
Running in new circuits is not really an option in my newly finished kitchen.
Other appliances on the same ring final are.
Washer/dryer
Fridge/freezer
850w microwave
kettle
Hope this is clear.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Jul 19, 2009 4:11 pm    Post Subject:
if it says 13A, then 13A it is..
that PDF lies though..
says "installation diagrams", but I didn't see any..
__________________
If you make everything idiot proof, evolution will just make a better idiot.
Back to top
 Alert Moderators
Master of None
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jul 19, 2009 4:16 pm    Post Subject:
Thankyou and I agree, But it looks like they have split a single document for use online because there are othe bits elswhere of the "installation diagrams" to do with installation into kitchen units etc. (woodwork).
Is it likley to be fitted with a molded plug so I can just plug it in? Money is now a bit tight. Or am I going to need an electrician to install and test.?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Jul 19, 2009 4:25 pm    Post Subject:
you buy a £700 single oven and quibble over £30 for a sparky to wire it in if it needs it? icon_wink.gif icon_rolleyes.gif icon_lol.gif
if it comes with a plug you can plug it in.
if it comes with a flex but no plug it will need hardwiring.
if it doesn't come with a flex at all then you need to fit one and hardiwre it..
__________________
Back to top
 Alert Moderators
Master of None
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jul 19, 2009 4:58 pm    Post Subject:
Cheers ColJack, will wait till it arrives and decide upon installation method. But I suspect £30 would not even get a spark into his van. Never mind run in a new circuit. Or are you saying he could just change the socket for a FS.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Jul 19, 2009 5:01 pm    Post Subject:
yeah, socket to a FCU.. an hours work at most..
__________________
Back to top
 Alert Moderators
Master of None
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jul 19, 2009 5:03 pm    Post Subject:
Cheers ColJack.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Jul 20, 2009 5:52 pm    Post Subject:
Re: Electric oven
Master of None wrote:
850w microwave
Consumption nearer 2kw.
850w is the output of the magnetron. The rest of the energy is used on the fan, electronics (timer), turntable, and inefficiencies in the magnetron.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Jul 20, 2009 6:01 pm    Post Subject:
what's that got to do with the price of fish?
he's not asking about his microwave, just including it in a list of appliances that he's already got on the kitchen ring
__________________
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Jul 20, 2009 6:45 pm    Post Subject:
I know, just making a point. Its a common misconception (though it doesnt really matter in most cases since its normally a plug n play thing)
Back to top
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 13 times
PostPosted: Tue Jul 21, 2009 3:07 pm    Post Subject:
I know, just making a point. Its a common misconception (though it doesn't really matter in most cases since its normally a plug n play thing)
Not sure about price of fish, but it may well be a good point. Look at the potential overall loading when the kitchen is in full swing. If the ring only supplies items listed, all good. But if same ring runs further around the house, you may start to overload.
There is a suggestion that items over 2kW should be supplied by its' own dedicated radial.
Assuming that the oven and hob both within 2m of the cooker control, is it not possible to get the supply for oven via the supply to hob?
Might only involve a FCU be fitted.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New Kitchen - Fitting Electric Oven 18 3360 Mon Dec 04, 2006 2:07 pm
Electric oven spur from ring main 4 540 Thu Nov 30, 2006 5:16 pm
NEFF Built in Double (Under) Oven & Electric Hob 4 3280 Mon Jan 01, 2007 6:17 pm
old gas oven & hob out: In electric oven and gas hob 4 300 Tue Jan 16, 2007 3:29 pm
Stand alone electric cooker to seperate oven and hob issues 4 1680 Mon Feb 12, 2007 2:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
