I have recently bought a ceramc floor lamp lit by a 150 watt halogen bulb. The light seems very white and cold compared to a nearby 60 watt tungsten lamp. Is there any way of gaining warmer lighting from the ceramic lamp?
you would need a photographic colour correction filter. 85B looks the best (it is an orange filter) trouble is they are fairly cheap for a camera because they are not designed to get hot you would need a colour correction gel which are usually available on a roll (they are designed for lights so can withstand heat) they are somewhat expensive.
Why not fit a dimmer switch to the lamp and dim it very slightly?
The lamp itself takes the form of an enclosed globe, so the heat build up must be quite fearsome. Can I presume that the filter will be a sort of drum that surrounds the bulb?
