DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Waste pipe fall angle
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
H0ckeynut
from United Kingdom
PostPosted: Mon Jul 20, 2009 2:28 pm Reply with quote
I'm trying to gauge the feasibility of installing a shower cubicle to an inside wall, and moving the basin to that same wall. What I needed to know was whether it would have enough fall to get to the outside wall. That would be about 2 metres away front he shower & basin location. And obviously I would be looking to achieve that fall underneath the floorboard. I think the pipe would be going in the same direction as the floor joists.
Any other thoughts or advice I should consider? And would I be able to get enough rate of fall to put these on that wall opposite the outside one?
Hope that was clear and not incoherrent babble!
Thanks,
David
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Mon Jul 20, 2009 2:58 pm Reply with quote
Fall required is between 18-90 mm per metre run but the maximum length for an unvented waste pipe run is 1.7m for 32mm diameter & 3m for 40mm waste. If the joists are at 90 degrees DO NOT notch them; Building Regs. cover where & to what extent you can drill & notch joists. If you tee the shower & basin into the same waste run you will need to fit either an air inlet valve or an anti-siphon trap on the basin run.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Should the condense pipe have a fall angle 33 540 Tue Sep 27, 2011 6:55 pm
Bath waste pipe angle. 17 320 Sun Jan 26, 2014 1:51 pm
soil pipe angle to stack 4 2340 Sat Jul 08, 2006 5:18 pm
Toilet - increasing soil pipe angle to improve exit of #2s 2 680 Sun Nov 09, 2008 9:36 am
Fitting toilet to soil pipe at funny angle 10 1840 Wed Jun 16, 2010 6:32 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
