Indesit WIDL146 - All service lights flashing
8 Jul 2009
Kent
Hello everybody (it s my first post here)
I have got all lights flashing on my washer dryer, indesit widl 146. Several times, I had just to unplug and replug and wait for a few hours. But it doesnt work anymore :(
I got it opened today to clean everything I could but it's still flashing
What should I replace and where to buy it? Or should I consider to get rid of the machine.
Thanks for your help.
Does this help? Indesit WIDL Codes
See also Hotpoint WF & some WD, left hand lights from top to bottom or digital display.(next page)
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Thanks, it does help.
Apparently, problem would come from the dryer heater relay.
Do I have to trust blindly the code or is there any way I can double check the relay is faulty? Is that something I can replace easily?
Cheers,
You could measure whether or not you have a voltage across the element terminals, if not it would seem to be a good indication that the relay is indeed faulty.
I tested the relay (or what I believed to be: something right on the top where hot air is blown). I had 4.1v between the element and earth at the entry but I could not access the other end. I dont think I would get anything anyway as the relay would be ON only during drying process. The machine does not even start.
Where can I buy a new dryer heater relay?
Nothing on indesit webiste :(
Hello,
Unfortunately, they do not have the part ;(
I talked to an engineer who could open and diagnose the washing machine for 40 quids plus part : do you think that s the way forward???
Regards
Hello rocks1,
How easy is it to remove and fit a new PCB?
Also, PCB are quite expensive. Are you sure this will fix the problem?
If yes, I will change it (or get it changed).
Thanks.
pcb is plug and play ,found at the rear of mc send to that company they will test it for a fiver .if its faulty cost is 45 new pcb fom indesit cost 90.00
Thanks to everybody who helped, particularly to you rocks1.
I ordered a new PCB (actually not new, but repaired pcb) from the website suggested, and I changed it myself. It was quite straight forward after all.
Cost was about £50 inc VAT provided that you return your faulty pcb.
Have a problem with my washer/dryer
The light to the right is blinking. As i understand its the column to the left that describes failure codes: Light 1,2,3,4. How about the column to the right?
It just blinks and wont start.
Wrote it abit wrong. Its not the one to the right. Its the one to the left(between the sun and 9h). Its not blinking but the diodes are blinking starting from top and and ending with the buttom 1. Lighting constant.
Checked filter and chanced the doorlock. Im wondering if its motor triac its wrong with? Is it the component called BTB16800B(in a housing like standard 3 pin LM7805)?
