OhGranny
Joined: 06 Apr 2006 Posts: 125 Location: Leeds, United Kingdom Thanked: 0 times
Posted: Thu Jul 23, 2009 9:21 am Post Subject: MultiFinish |
Hi
I am plastering around the window reveal after removing the tiles.
I have some multifinish for skimming but it says to spread about 1 to 2mm thick.
Trouble is the reveal is really badly out of square.
I reckon to square it up the plaster will have to come out to at least 8mm thick like a cheese wedge!
Can I use multifinish to this depth or will I have to do it in layers filling out gradually, or use the patching plaster first with a thin layer of multi on top?
G. |
Richard C
Joined: 26 Apr 2005 Posts: 4318 Location: Norfolk, United Kingdom Thanked: 48 times
Posted: Thu Jul 23, 2009 9:26 am Post Subject: |
Personally I would use Bonding plaster to level it off first & then skim. Multi can be applied 2-5mm thick so you could build it up in, say, 3 coats but it may well craze badly if you dont get it right.
Are you using an angle bead around the outside edge of the reveal? __________________ Richard C |
OhGranny
Posted: Thu Jul 23, 2009 11:12 am Post Subject: |
Hi Richard
I will be building up on the existing one. I was hoping to avoid putting another one in. I am skimming the wall as well. I was going to fix a batten on wall level on the vertical both ways to give me a guide to plaster up to.
G. |
Richard C
Posted: Thu Jul 23, 2009 11:52 am Post Subject: |
If you’re skimming the wall as well, I’d definitely fix another thin coat angle bead on there after you squared up the reveal. It'll give you a nice straight edge to work to rather than trying & "feather" which, because of the grit size in Multi, can be difficult for the inexperienced; working up to a new bead will make your life a whole lot easier & a sharp plaster corner will also damage more easily. __________________ Richard C |
OhGranny
Posted: Thu Jul 23, 2009 12:47 pm Post Subject: |
Hi
I presume you can get 'thin coat angle bead' then.
I was trying to avoid it because as I remember the angle bead I last used sits quite proud from the wall.
I didn't expect to put that much plaster on the wall!
I'll let you know how I get on.
G. |
DIYnewbee99
Joined: 25 Oct 2008 Posts: 207 Location: Cheshire, United Kingdom Thanked: 1 time
