Negative points regarding screws v nails for oak floor fix
19 Jan 2007
London
Have finally ordered some Elka 18mm oak floor in aged golden oak.
Since I have a few battery drills and don't have a 45 deg floor nailer I was thinking of using self drilling floor screws designed by Elka for the fix.
I accept that the fixing will take more time, but that's not an issue since the work is for me.
So is there any negative aspects of using flooring screws which self drill and countersink over the generic nails?
From my (limited) knowledge I would think:-
Screws will provide a firmer, less movement fix.
More chance of debris due to screw self drilling- countered by having the vacuum in action after each row completed.
Big question is do you pro's have any real argument / reason why you would use nails over screws (other than time = money).
Ta to any that offer advice / considerations.
We know Elka has special screws 'invented' to be used with their floors, so if something does go wrong you can address them.
However, we still doubt the product - call us old fashion if you like ;) - but nails will allow the floor some movement when it expands/shrinks due to the angle. I can't see screws allowing the same and have seen disastrous effects of screws where the whole board was ripped in two - wood is very strong and if it wants to go it goes, no matter what screw you use.
We've not used Elka screws and we don't plan to use them either, but if you trust the product and believe the claims - go ahead.
:eek:
I read that as a full legal caveat, as in buyer beware- but we wouldn't..
:D
