Hi, see if I can tempt the structural engineers with this one Please..
For a decking project I am planning post and beam assy with 187x69mm single beams slotted onto 144x144mm posts and with 170x45mm joists across beams topped with 120x33mm deck boards.
I am understanding (don’t ask me to prove it!
) that from reading various sources that with above setup 1.8 is max between the posts supporting beams and 2.7m max between the beams which will support the 170x45 joists which are at right angles to the beams; with joists at a max of 400mm centres.
Current standards recommends that minimum a raised deck should be able to withstand is a “uniformly distributed load of 3.0 kN/m2 and concentrated load of 1.4 kN for the main deck platform and its support”
The question is can you tell me where I might find the calcs to see whether my proposed setup might meet this minimum standard as I’m thinking they might(?) not be that complicated that I might be able to follow them.
I fully understand and would be intending employ a structural engineer to provide the actual calcs and more if I go ahead but this is to reassure myself that what I’m currently pricing and sizing up might be in right ballpark.
Thanks in advance, cheers
