| Author |
Message |
Nicetoseeyoutoseeyounice
Joined: 18 Sep 2006 Posts: 246 Location: Lancashire, United Kingdom Thanked: 1 time
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
wanleg
Joined: 11 Apr 2005 Posts: 372 Location: Hartlepool, United Kingdom Thanked: 14 times
Posted: Sat Aug 01, 2009 11:43 pm |
Usually the hard drive is quite easy to physically replace....do you know what to do once you have physically replaced the drive ?
Which model laptop and which operating system are you running ?
Are you sure you have the required operating system/recovery disk(s) to reload once a new drive is fitted ? |
| Back to top |
dave.m
Joined: 20 Jul 2007 Posts: 1743 Location: Lancashire, United Kingdom Thanked: 126 times
Posted: Sun Aug 02, 2009 12:03 am |
Some instructions here
dave |
| Back to top |
Posted: Sun Aug 02, 2009 10:37 pm |
Thank you for the replies.
The instructions you say to follow are pretty much what I have already read but I honestly could not believe it could be that simple (well, simplish).
My laptop is an Acer Aspire 5630, it is 64bit and I was, running Windows Vista.
Now, would I have to reinstall Vista or can I change to XP. Also if I do have to install Vista, foolishly I did not make a recovery cd or back up when I got the laptop so now I do not have a recovery cd, but again, from I read I think I can purchase one of these if neccessary, although I would prefer Windows XP to run on it.
The swopping the hard drive bit dosnt seem too bad, its the things you have to do after you have installed it that worry me. Is it quite a straight forward process????  |
| Back to top |
tim west
Joined: 27 Nov 2006 Posts: 11900 Location: United Kingdom Thanked: 8 times
Posted: Sun Aug 02, 2009 10:55 pm |
having an Acer backup disk is not the same as having the OS disks the acer one is an image file that needs the necessary cd boot drivers that youd need to install on the new drive first |
| Back to top |
Posted: Sun Aug 02, 2009 11:19 pm |
| Back to top |
mattylad
Joined: 26 Apr 2008 Posts: 3492 Location: Lancashire, United Kingdom Thanked: 83 times
Posted: Mon Aug 03, 2009 8:29 am |
Sounds about right.
You may be needing an install key though  |
| Back to top |
Posted: Mon Aug 03, 2009 5:12 pm |
What is an install key? also would I be able to install XP or does it have to be Vista? |
| Back to top |
Posted: Mon Aug 03, 2009 9:41 pm |
Sorry please excuse my ignorance. The install I know is the key code number which I would hopefully get when I download. Now I know what you mean about if I download Vista I would need this number.
I havnt thought of that but I am sure I would find out when I download. It dosnt seem to cost much to download so maybe they send you one, I would have to find out.
So as the process seems simple enough to install a new hard drive, what is the process once this is installed?? |
| Back to top |
macro01
Joined: 18 Aug 2009 Posts: 16 Location: Manchester, United Kingdom
Posted: Wed Aug 19, 2009 4:42 am |
when you have installed the HDD, boot up with the DVD you got and install it. put the install key and applicable settings for vista. i think that's it |
| Back to top |
