DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cutting a hole in a cavity wall for an extractor fan ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
STEVEROG
from United Kingdom
PostPosted: Tue Aug 04, 2009 6:33 am Reply with quote
I need to cut a hole into a cavity wall to fit an extractor fan. I guess the best way to do this would be to use a large core drill but I do not have one of these. So...
1. Do I need to buy / hire a core drill?
2. Is there another sensible way I can do this without a core drill
In addition, do I need to add any support such as a lintel or other reinforcement where I cut the hole?
The hole will be at the centre (left to right) of a gable end wall of a bungalow. The wall is rendered brick on both sides.
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 47 times
PostPosted: Tue Aug 04, 2009 7:26 am Reply with quote
How big a hole?
Biggest I have installed was a 12" Expelair - would not want to use a core drill for that.
Choice is a core drill or stitch drill - a series of holes around the circumference and break out the centre.
Depends how neat you want the inside & outside to look.
Back to top
 Alert Moderators
STEVEROG
from United Kingdom
PostPosted: Tue Aug 04, 2009 7:32 am Reply with quote
It's looks like a 6 inch fan so I assume the hole size is approximately this size. The stitch drill is worth considering but I will see how much it will cost to hire a core drill for a day. This might save me some time and give a better end result.
Steve
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Cutting a hole in the wall for a door 2 720 Fri Jan 05, 2007 9:43 am
cutting a hole in my cast concrete wall...REBAR ? 14 1620 Mon Jul 26, 2010 6:50 pm
Cutting hole in external house solid wall for flue pipe 2 60 Mon Feb 25, 2013 8:29 am
Cutting hole through wall in downstairs toilet to connect to 4 600 Sat Sep 26, 2009 9:27 pm
Cutting hole in supporting wall.... HELP 5 140 Sat Jan 19, 2013 6:23 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
