Epoxy resin and fibreglass resin?
14 Oct 2008
Surrey
I am going to glue a load of cut n bond engineering bricks together, the price for Araldite would be huge, so I'm thinking of using fibreglass resin cos it's cheaper. Will this be OK? and out of interest, is epoxy resin and f/g resin the same thing?
Why not use the proper coloured adhesive, often see it used on the corner bricks for conservatories
Fibreglass resin is a polyester resin and will not react well with any moisture that is in the bricks, it also remains tacky in the presents of air.
I mostly use West Systems epoxy adhesives, should be something in their range to suit your needs
Jason
Fibreglass resin doen't really stick to things. When used as a pond liner, it's recommended to paint a polyurethane bond coat onto the base before fibreglassing because it might not otherwise stick.
So I guess fibreglass resin and epoxy adhesive resin are not the same thing.
I take it you're looking at creating a wall with funny angles in them. My advice, for what it's worth, is not to bother bonding them at all, but lay then as normal withour mortar joints on the corners (you can always squeeze some mastic in later), and use metal wall ties over each joint to provide lateral strength.
Jason............West systems, the nearest seems to be Bristol but I'm in Surrey
