Plasterboarding in Bathroom - Cutout Pipes Before Skimming?
30 May 2009
Yorkshire
Hi All,
I'm about to plasterboard upstairs, including the bathroom.
The radiator and shower pipes all come out from stud partition walls, not he floor.
should I:
A) cutout pipe holes in plasterboard and have the pipes sticking out before skimming.
The disadvantage here is it will be difficult for plasterer to get float around/between pipes to leave a smooth finish.
B) Skim 1st then cutout from other side of the stud wall.
The disadvantage here is I would have to wait for plaster to go off before I could cut out from the other side. Only then would I be able to plasterboard this side and skim.
Hope I've explained this correctly? Which is the correct way to do this?
no real correct way i would say.
you're right in thinking it's easier to skim a flat board with no obstacles but a decent plasterer should have small 'pipe/margin trowels; for these types of jobs, still may not be as good as if the pipes weren't there but don't forget they'll be largely hidden anyway.
the skim will dry very quickly on plasterboard, a day probably in this weather, better to cut from the plaster side i think too unless you need to cut from the back?
if you do take option 2 you could be boarding while she's skimming, except of course if you're slow he'll catch you up retty soon.
note: don't forget to leave a gap at the bottom of the plasterboard when fixing, sue some cutoff bits of board to sit the boards onto while you screw then remove them
sorry if i'm teaching you to suck eggs, just thought i'd mention it
Thanks for the suggestions - any advice is much appreciated.
I'd never done any plasterboarding before, but I've read quite a few guides on what to do now, so I think I'm about ready to give it a go.
One other question I had (I'll post another thread if thats more appropriate?) is regarding the doorframes.
Should I board up to the 3x2 framework, then put the doorframe in after?
I've measured up and if I put the door frame in the centre (depth) there is about a 10mm protrusion on either side. This means when the plasterboard/plaster goes on, there will be a step down to the doorframe. So when the architrave goes on around the frame, it wont be at 90 degrees to the frame.
Hopw I've explained this well enough? i can easily draw a diagram if it helps?
