DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower pump keeps tripping fuse
Author Message
Steady
from United Kingdom
Thanked: 26 times
PostPosted: Tue Aug 11, 2009 8:22 am Reply with quote
I have a 1.5 bar Newteam Duraspeed twin impeller shower pump feeding a mixer shower.The pump has worked fine for the past 12 months ,though it wasn't new when installed (I got it from another job)
It is wired via a 3A switched fused spur and it takes its power from the upstairs lighting crcuit(not my idea)
Recently the pump started to take 30secs to kick in when the sjower was turned on but has now tripped the 6A breaker in the consumer unit. I was still getting power into the fcu but nothing out. I replaced the fused spur and the pump worked again but a week later the same thing has happened again.
I then took away the fcu and wired the pump straight to the lighting circuit but now the pump starts up even when there is no demand from the shower.
Is this likely to be a fault with the pump? No other problems anywhere else in the house.
Back to top
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 86 times
PostPosted: Tue Aug 11, 2009 8:44 am Reply with quote
yes, very likely to be a fault with the pump.
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 26 times
PostPosted: Thu Aug 13, 2009 5:37 pm Reply with quote
Ok. I've put in a new pump and it works okay.
BUT- I tried refitting a new fused spur between the pump and the supply from the lighting circuit and there's no power going out to the pump again-and it was a brand new fused spur with a new 3amp fuse.
What's that all about? can't be a second faulty fused spur surely?
I have had to remove it again to get power to the pump.
Back to top
 Alert Moderators
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Thu Aug 13, 2009 6:02 pm Reply with quote
I doubt there was anything wrong with the first fused spur.
Have you tested the fuse?
Have you tested the load side of the spur?
Are you sure no power is getting to the pump?
The reason I say these things is that it could be that the pump is not kicking in because you have a low head problem with the water supply to the pump. Is it a positive or negative head pump? Is there much distance between the shower head and the cistern?
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 26 times
PostPosted: Thu Aug 13, 2009 7:05 pm Reply with quote
there is no power on the load side of the fused spur- i've tried about 4 different fuses in it- p'raps i keep picking the same one up and putting it back in each time!
When i bypass the fcu there is power all the way and pump works fine.
The plumbing side of it is all sorted and previous pump worked ok for 12 months.
Just wondered if it was common for fused spurs to malfunction? - as I came across one the other week supplying a boiler-it just didn't work and it wasn't the fuse. New one sorted it.
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 146 times
PostPosted: Thu Aug 13, 2009 7:12 pm Reply with quote
Double check connections in back of spur. Could be wired incorrectly etc
Back to top
 Alert Moderators
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Thu Aug 13, 2009 7:17 pm Reply with quote
Ok, just checking. If you have measured no voltage on the load side and have tested the fuse (before and after fitting it!) then it must be a faulty fcu, unless as pointed out you have it wired up wrong.
These things do go wrong, but not normally new ones.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Shower Pump tripping RCD 9 640 Thu Jan 22, 2009 1:44 am
New Shower Pump RCD tripping 2 80 Fri Jan 14, 2011 8:38 am
Power Shower Pump tripping breaker 7 780 Tue Dec 20, 2005 3:32 pm
Please help - pond pump & filter tripping circuit 14 820 Sun Jul 19, 2009 9:52 am
Can you fit a timer to a shower pump? 20 1300 Sat Apr 03, 2010 4:58 pm
DIYnot
