DIYnot
Local | Network
   DIYnot > Forums
Local | Network
parkray chiltern to twin coiled cylinder help pls!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
WHITWOO
from United Kingdom
PostPosted: Mon Aug 17, 2009 9:57 pm Reply with quote
HI TO ALL! I am a gas safe engineer and have to price up a new boiler job, british gas have also put a price in. the job requires a system boiler to a twin coiled cylinder the other coil to be connected to the exsisting parkray chiltern fire/back boiler this will require cutting of the heating circuit from the fire (apart from the one heat leak radiator)
parkray say it ain't a good idea but are they just covering there backs? the fire ain't gonna be completely sealed off after all and will be open vented from the cylinder circulators, its only the heating circs that will be capped off.
I just need help on this one cos i don't have a lot to do with solid fuel, thanks!
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 944 times
PostPosted: Mon Aug 17, 2009 10:24 pm Reply with quote
proberbly parkray are saying this is, due to the fact the heat ex on the boiler is designed for heating and dhw. hence volume of water heated by the fire may exceed the heat leaks requirement and cause overheating.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Parkray Chiltern - not heating radiators 5 200 Sun Dec 12, 2010 6:03 pm
Parkray Chiltern and my central heating system/ hot water 7 740 Tue Aug 12, 2008 12:08 pm
parkray chiltern is a pain 8 760 Thu Nov 15, 2007 7:37 pm
Parkray Chiltern Back Boiler 5 120 Tue Dec 21, 2010 5:33 pm
Parkray - possible leak... 3 440 Sat Jan 07, 2006 8:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
