DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Underground pvc to clay chamber advice please
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Fluffster
from United Kingdom
Thanked: 2 times
PostPosted: Tue Aug 18, 2009 8:04 pm    Post Subject:
Reply with quote Thanks
Hi Guys
I need some advice please on underground drainage which I very rarely get invloved in.
I need to spec for a 100mm pvc soil pipe to connect into a 200mm clay sewer on a swept t junction with a inspection chamber
The depth of the clay pipe is approx 1200mm and is a combined waste sewer running along the back gardens of a row of about 10 houses built early 1900s we are in the middle of the run.
Is there a pre moulded chamber that will accept the 200mm pipe or will I have to build a formed concrete base with brick walled chamber.
Any advice would be most helpful.
Thank you.
Pete
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Hugh Jaleak
from United Kingdom
Thanked: 28 times
PostPosted: Tue Aug 18, 2009 10:43 pm    Post Subject:
I think preformed plastic bases are only made for 110 and 160mm dia. pipes. I would suggest (BCO allowing) your best bet would be to excavate and expose the existing 9" pipe, then carefully cut and remove the top half of a section to form a channel, and construct a masonry manhole around it.
BCO will advise on what they want to see, its also possible they may need you to remove a section of existing pipe and replace, thus providing an expansion joint in the existing run either side of proposed manhole.
9" pipe for 10 houses seems a bit excessive to me, but there may have been further intention to connect into it at the time it was laid. Be aware an excavation of that depth will require support too.
Back to top
 Alert Moderators
Fluffster
from United Kingdom
Thanked: 2 times
PostPosted: Wed Aug 19, 2009 6:55 am    Post Subject:
Cheers for that, I will speak to the approved inspector they are using for the job.
Much obliged
Pete
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Clay Underground Drainage 9 2300 Mon Apr 30, 2007 4:22 pm
Plastic to clay soil pipe join and connecting WC problem 20 6900 Wed Apr 19, 2006 11:27 am
Clay soil connection 5 920 Mon Jun 05, 2006 3:26 pm
soil pipe connection upvc/clay 5 220 Fri Oct 02, 2009 3:08 pm
vent for clay tiles 2 60 Wed Sep 23, 2009 4:33 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
