xerxes
Joined: 13 Jan 2006 Posts: 970 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Aug 19, 2009 10:03 pm Post Subject: Drill chuck removal |
I've just acquired a secondhand Elu mains drill (EMD403); I'd like to change the chuck for a better one if possible.
Looking inside the chuck where I'd expect to find a retaining screw (the drill has reverse), I can see what looks like a screw. It has a very shallow slot, with a dimple in the centre. It seems to turn freely in either direction, without undoing or tightening. The slot is so shallow that it's hard to get a screwdriver to engage in it.
(The exploded diagram I've found for the drill does show a screw, but the definition is too poor to give any details.)
On the shaft behind the chuck there are no flats where I'd expect to find them, to hold the shaft while the chuck is unscrewed.
Does anyone have any ideas on the way to remove this chuck? It's marked 1/2 - 20, so I know it's a screw mount. |
ColJack
Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Thu Aug 20, 2009 12:43 am Post Subject: |
screw is probably a security screw.. the dimple in the middle prevents the use of a regular flat screwdriver.
to remove the chuck, screw it clockwise, they have a reverse thread..
the "shock" method is the way to remove the chuck.. put an allen key into the chuck and grip the drill securely ( a vice works well ).
strike the allen key in the right direction.. it WILL spin, so watch your knuckles..
it should shock the chuck loose..
if not try it again until it does.. __________________ If you make everything idiot proof, evolution will just make a better idiot. |
xerxes
Posted: Thu Aug 20, 2009 10:38 am Post Subject: |
Thank you. The centre of the screw has a dimple (a depression, concave); it doesn't prevent a normal flat blade seating in the slot. The problem is that the screw doesn't seem to be threaded, either left or right hand: turning it doesn't do anything.
And yes, I've already tried the usual method of fitting a large hex key in the chuck and smacking it with a hammer. It doesn't have any effect. |
gregers
Joined: 28 Mar 2008 Posts: 1100 Location: Sussex, United Kingdom Thanked: 29 times
Posted: Fri Aug 21, 2009 2:36 pm Post Subject: |
you might also find that it just unscrews,iirc anti clockwise. __________________ reality is for people with no imagination |
