DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Confused about dripping external overflow pipe
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
josephkao
from United Kingdom
PostPosted: Sat Aug 22, 2009 3:28 pm Reply with quote
Hi all,
Me and my girlfriend have just bought a new flat (our first!) and it's second (top) floor. There is a dripping thin white pipe causing puddles on the ground floor patio, and unsurprisingly, they've asked us if we can do something about it.
The pipe is located on the outside wall, about 2-3 feet under where the toilet is in the bathroom. It drips intermittently, sometimes not at all, sometimes a drop every 5 seconds, sometimes it's close to a continuous trickle.
After a lot of googling, I was going to replace the ball cock (and its washer) in the toilet, but after examining the toilet I don't see how this could fix the problem. The ball cock is correctly positioned, and even if the washer's old, I don't understand why a dodgy washer on the inlet pipe to the toilet cistern would result in dripping water on an external white pipe. I've even held down the ball cock to let water go into the toilet overflow, and it doesn't affect the external white pipe, the water just goes straight into the toilet - so is it even serving the toilet at all? What do these mysterious white external overflow pipes normally connect to?! (Really exposing my ignorance here...)
I also have a condenser boiler in the adjacent kitchen, and after bleeding the radiators the pressure went down from 1.6 bar to 1.3 bar (I do know how to raise it again if needed), and I wondered vaguely if that could affect it, but no change (and it's definitely not the flue vent).
The other mystery about the flat is I have *no idea* where the cold water tank is. It's a conversion of an Edwardian terrace into two flats and a shop, and we have access to a loft over the lower level of the flat, but all the old water tanks in there are empty and out of use (which baffled me when I first went up there!). There is also a raised level of the flat (it's split level) with roof space over it, but there's no access hatch for there. Logically, I guess it must be over us somewhere, but surely it can't be permanently sealed!? Anyhow, I don't think the white overflow pipe is connected to the cold water tank, and it's too low down for that.
Yes, I could call a plumber, but since it's not an emergency, I thought I'd find out if it's anything simple and obvious. Any ideas? I mean, for a start, could anyone explain how these little white overflow pipes normally link to the toilet plumbing?
Joe
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sat Aug 22, 2009 3:30 pm Reply with quote
its poss the condensate pipe from the boiler
Back to top
 Alert Moderators
josephkao
from United Kingdom
PostPosted: Sat Aug 22, 2009 4:01 pm Reply with quote
Cheers Kev - that makes sense. Do you know if the dripping is normal, and whether the condensate can be drained internally if necessary?
Back to top
 Alert Moderators
Johnmelad502
from United Kingdom
Thanked: 49 times
PostPosted: Sat Aug 22, 2009 6:17 pm Reply with quote
Could be the toilet overflow. Lift the lid on the tank and see if the water is up to the level of the overflow. You might just need to lower the ballcock.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Aug 22, 2009 6:18 pm Reply with quote
It is illegal to have a condensate pipe just hanging out the wall. Is it an ideal by any chance?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sat Aug 22, 2009 7:29 pm Reply with quote
really which law does it contravene icon_question.gif icon_question.gif icon_question.gif
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Aug 22, 2009 10:12 pm Reply with quote
If nothing else, the GSIUR. Appliance must be installed conform M.I. and every one I have ever seen tells you to either connect to drain or terminate in soakaway.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sun Aug 23, 2009 12:03 pm Reply with quote
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sun Aug 23, 2009 12:57 pm Reply with quote
kevplumb wrote:
Did I say it is a law?
It's illegal to contravene the GSIUR, whether it is a law, bylaw, statute or regulation
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sun Aug 23, 2009 1:05 pm Reply with quote
err if it ain't law then how can it be illegal
its not illegal
however ignoring a statute can be used to bolster a prosecution
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 833 times
PostPosted: Sun Aug 23, 2009 2:20 pm Reply with quote
As you`re over there now, what`s the difference between a statute and those ammendments icon_question.gif
I`m taking the 5th. now
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sun Aug 23, 2009 4:06 pm Reply with quote
Am I mistaken then that people have successfully been prosecuted for contravening the GSIUR? icon_confused.gif
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 239 times
PostPosted: Sun Aug 23, 2009 5:25 pm Reply with quote
i dont know, when was the last one for leaving a condensate drain "hanging out of a wall"?
link please.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sun Aug 23, 2009 6:08 pm Reply with quote
Back to top
 Alert Moderators
jiltedjohn
from United Kingdom
Thanked: 1 time
PostPosted: Fri Aug 28, 2009 3:28 pm Reply with quote
the law of "common bleedin sense" icon_razz.gif icon_smile.gif would you want condense dripping down your wall rotting the mortar and staining the brickwork?
and yes the condensate can be routed into the bath or basin waste.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Gas pipe-gas pressure-rendering-Joe Public confused ! 4 400 Mon Apr 06, 2009 12:49 pm
Pipe size--I am confused ! 29 1360 Tue Apr 28, 2009 5:45 pm
Heating probs, not am idiot, just confused 2 80 Mon Dec 19, 2011 2:54 pm
Confused about combi boilers and hot water only 10 100 Mon Sep 26, 2011 6:42 pm
Heating issue (Confused) :roll: 3 60 Sun Oct 23, 2011 1:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
