Back off the gland nut - that s the one just below the turning handle. Try working the tap gently. Get in there with some WD40 and if you're luck is in, the tap will eventually come free although some can be seriously tight. Whatever you do, don't undo the main tap body hexagon or you'll be swimming for it....! Cheers John
turn the water off ouside and take the guts out of the stopcock and give it a good overhaul plenty of water based silicone grease and the jobs a good un
