sealing in the water?
12 Feb 2006
I'm about to cover a box valley with Ubiflex lead substitute. The floor is 18mm ply and has just had a biblical sized flood on it. Should I let it dry out before covering or doesn't it matter? I'm worried about the moisture causing mould, rot etc.. Thankls in advance
Hi
I'm no expert but I have had a lot of problems with my roof, I would suggest that you let the valley dry out as much as you can before you cover it.
Red
