DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton Performa 28 pressure problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
vygec
from United Kingdom
PostPosted: Sat Aug 29, 2009 10:52 am Reply with quote
problem with our boiler, hope someone can help.
the hot water takes a very long time before it comes on, ive noticed the pressure gauge is always sitting at 0.
we have had the boiler for 7 years, and was serviced last summer.
i was under the impression that one could re-pressurise the boiler by turning a knob from underneath the boiler, there are two underneath, turning these has no effect.
So is this a job for a professional, or anything else i can try?
the service is due for this year, im thinking i may mention it to the service engineer at the same time, but will it be an expensive job?
Thanks.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sat Aug 29, 2009 10:54 am Reply with quote
turn them both on together
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3610 times
PostPosted: Sat Aug 29, 2009 10:59 am Reply with quote
If you cannot repressurise it then you could see if you have the skills to replace the filling loop yourself. Its quite a simple job but has the potential to cause a flood if you get it wrong.
Otherwise most engineers would treat it as a repair rather than a routine service.
We charge just 55 for a service but 84 for a repair in our local area. We only do a service when we can fit it in and usually about a week after the call whereas a repair is normally done the same day.
Tony
Back to top
 Alert Moderators
vygec
from United Kingdom
PostPosted: Sat Aug 29, 2009 11:20 am Reply with quote
ive turned both knobs, left them for a while, and this has made no change.
Any other ideas?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sat Aug 29, 2009 11:41 am Reply with quote
try removing the silver pipe and turning the valve on
does any water come out ?
it could be a dodgy plastic top on the valve ie the top is turning but the valve aint icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton Performa 28i boiler - air pressure problem? 6 1420 Sun Aug 10, 2008 10:48 am
Problem with low and high pressure in Potterton Performa 28i 4 1040 Wed Sep 23, 2009 9:52 am
Potterton Performa boiler pressure at 3.00 bar when cold 4 360 Mon Jan 25, 2010 8:35 pm
Potterton Performa 28i - low pressure - radiatiors not work 9 3900 Sun Oct 01, 2006 5:02 pm
Potterton Performa 28i Losing pressure - PRV and AAV? 5 740 Sun Apr 11, 2010 3:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
