DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Greenstar 24i/28i junior
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mojamster
from United Kingdom
PostPosted: Tue Sep 01, 2009 4:41 pm Reply with quote
I have to remove a radiator and fit a small one as a result of room alterations. Is it in order to close down all valves on the remaining rads to retain the water in them leaving only the valves open on the rad to be removed, and then open the drain-off tap to empty the rad and the flow & return pipes so that I can alter one pipe to fit the new small rad???
Also is it correct to turn the above boiler off, electrics off, and the water supply to the boiler off so that the water in the in the boiler does not keep a supply going to the central heating system as I drain down??
All advice will be most appreciated,
mojamster
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 187 times
PostPosted: Tue Sep 01, 2009 4:49 pm Reply with quote
Boiler needs to be manually filled so no need to turn any water off to it. Advisable to turn electrics off as you dont want it firing with no water in it.
Best to drain down the whole system if you need to alter pipework. Doesn't take long to re-fill
Back to top
The following user says thank you to Rob for this useful post:
mojamster (1 Sep 2009)
 Alert Moderators
mojamster
from United Kingdom
PostPosted: Tue Sep 01, 2009 8:18 pm Reply with quote
Hi rob884,
Thanks for the advice, I will drain down fully as you recommend.
I guess my thinking about leaving the radiators filled was to retain any additive that may be present in the existing water.
I suppose adding inhibiters later should not prove to be difficult.
Regards,
mojamster
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2525 times
PostPosted: Tue Sep 01, 2009 10:23 pm Reply with quote
If you are only removing one rad just turn that one off and remove the rad after draining it from the union.
If those valves dont leak then you can continue to use the boiler for DHW and CH if you wish.
When you are ready to modify the pipework then do as you suggested but first isolate the boiler flow and return and turn off each rad. That method will preserve any additive and even if there is none then it retain the deoxyginated water in the system.
Tony
Back to top
The following user says thank you to Agile for this useful post:
mojamster (3 Sep 2009)
 Alert Moderators
WDIK
from United Kingdom
Thanked: 55 times
PostPosted: Tue Sep 01, 2009 10:48 pm Reply with quote
get the bleed screw adaptor and pump out rad with air its cleaner icon_wink.gif
Back to top
The following user says thank you to WDIK for this useful post:
 Alert Moderators
tamz
from United Kingdom
Thanked: 269 times
PostPosted: Wed Sep 02, 2009 1:10 am Reply with quote
Back to top
The following user says thank you to tamz for this useful post:
 Alert Moderators
mojamster
from United Kingdom
PostPosted: Thu Sep 03, 2009 10:09 pm Reply with quote
Hi to Agile (Tony), Wdik, and Tamz,
Many thanks for all the good advice and help.
I now have the radiator removed and will be fitting the new one tomorrow.
I hope that this next stage will go OK.
It's great to think that there are people out there who are willing to take the time to help others.
Best regards,
Jim (mojamster)
Back to top
 Alert Moderators
Maboza-Ritchy
from United Kingdom
PostPosted: Fri Sep 04, 2009 6:37 am Reply with quote
Hi
I'm doing similar work as Mojamster. Can someone explain in idiot-proof language how to repressurise this boiler using the filling loop?
TIA
Steveo
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 269 times
PostPosted: Fri Sep 04, 2009 7:47 pm Reply with quote
1) Connect the braided hose (if not already connected)
2) Turn the black lever, or levers if there are two, 1/4 turn in line with pipe. You will hear the water running through.
3) Watch pressure gauge rise to over 3bar.
You should now hear a soothing banging noise and if you quickly run to the outside of the building you should see water coming out a pipe. You have now confirmed your PR valve is working.
Never completed my modules for the rest. Will let you know when i have icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How to remove thecover from a worcester greenstar 28i junior 11 540 Fri Sep 28, 2012 7:47 am
Worcester Bosch Greenstar 28i Junior boiler 5 360 Fri Sep 23, 2011 7:06 pm
Worcester Greenstar Junior 28i provides DHW but not CH 9 140 Sun Apr 29, 2012 1:16 pm
worcester bosch greenstar 24i junior pressure problem 4 9900 Tue Apr 17, 2007 6:04 am
my Worcester Greenstar 28i Junior can't ignite 7 1080 Thu Jul 17, 2008 1:21 pm
DIYnot
