Joe100w
Joined: 04 Apr 2009 Posts: 30 Location: United Kingdom Thanked: 0 times
Posted: Wed Sep 09, 2009 5:31 pm Post Subject: Mirror Support |
I have a large mirror to fit. It is about 2 metres wide by 1 1/2 m high. It comes with a wooden Frame about 1 in wide. There is one way to fix it and it will have to be by hooking it on 2 white plastic caps which is recessed into the frame which will need a small hook (maximum width about 10 mm) to be fixed to the wall.
Problems - what sort of hooks can I get which is strong enough to support that weight without bending it and it needs to be fixed into a stud wall with nothing behind where the two hooks will have to go.
All suggestions welcomed.  |
3guk
Joined: 13 Sep 2009 Posts: 59 Location: London, United Kingdom Thanked: 3 times
Posted: Wed Sep 16, 2009 10:48 pm Post Subject: |
Any chance you could upload an image of the fixings on the back of the mirror, will help us to find a solution !! |
Joe100w
Posted: Thu Sep 17, 2009 8:43 pm Post Subject: |
Will do so next week and I am away for time being.
thanks |
Goldspoon
Joined: 20 Jan 2008 Posts: 752 Location: Anglesey, United Kingdom Thanked: 9 times
Posted: Fri Sep 18, 2009 8:16 am Post Subject: |
Firstly you cannot reply on the plasterboard of the stud wall. Either add a wooden noggin in the wall or cut away the platerboard and affix ply to the same thickness in its place and screw into this. |
