| Author |
Message |
flameport
Joined: 10 Mar 2007 Posts: 3560 Location: Bournemouth, United Kingdom Thanked: 531 times
Posted: Sat Sep 12, 2009 8:16 pm |
This machine has had minor problems for while, in that it sometimes missed the spin cycle at the end (although it would always spin properly on the spin/drain setting).
Now it won't spin at all, it gets through the washing part of the program and at the point it is supposed to rinse and spin, it just moves the washing around at low speeds with the drain pump running all the time.
I've already cleaned out the pump and the drain hoses leading to/from it.
Any suggestions? |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
cakeman
Joined: 27 Nov 2006 Posts: 389 Location: Surrey, United Kingdom Thanked: 49 times
Posted: Sat Sep 12, 2009 8:49 pm |
motor would seem & fault
check brushes , could be capacitor on the side
or try a new 2nd hand one , casaparts.co.uk have a good value supply
worth a try or espares.co.uk for a new one |
| Back to top |
flameport
Posted: Sun Sep 13, 2009 2:27 pm |
There is no capacitor on the motor.
The brushes have about 20mm of length left on them, no sign of any damage to the contacts on the motor, no loose wires in the connecting plug/socket. |
| Back to top |
cakeman
Posted: Sun Sep 13, 2009 2:33 pm |
either drain blocked or motor faulty |
| Back to top |
judith111
Joined: 08 Apr 2010 Posts: 2 Location: Cardiff, United Kingdom
Posted: Thu Apr 08, 2010 5:24 pm |
| flameport wrote: | This machine has had minor problems for while, in that it sometimes missed the spin cycle at the end (although it would always spin properly on the spin/drain setting).
Any suggestions? |
Hi . Would love to know if you solved problem on your Beko wash machine. Ours seems to have identical fault and we have cleaned out pump & hoses. |
| Back to top |
Leccy758
Joined: 18 May 2008 Posts: 1256 Location: Cornwall, United Kingdom Thanked: 193 times
Posted: Thu Apr 08, 2010 6:32 pm |
Starting point would be to check the motor brushes for wear. |
| Back to top |
judith111
Posted: Fri Apr 09, 2010 10:22 pm |
Thanks to Leccy758. Replaced worn brushes and seems to be working fine. |
| Back to top |
stef99
Joined: 01 Dec 2010 Posts: 42 Location: United Kingdom
Posted: Mon May 16, 2011 12:50 pm |
Hi, I have the exact same proble, however my bushes are fine.
When I use the machine, it will start, everything will work problerly, like filling etc, and the drum will spin, however, It will stop half way through the wash, Like its crashed like a computer or something, I have reset the machine 100's of times and cannot find the fault, could my door catch be faulty? |
| Back to top |
stef99
Posted: Sun Jun 12, 2011 12:44 pm |
Hi, If you pull the PCB off the machine and have a look at resistors R19 and R36, they may be worn. I found mine burnt out completely, It turns out this is a common fault on these machines and a replacement PCB is approx £65, I had decided to buy another machine for £50, but the resistors can be replaced fairly easily with a soldering iron, I am still wainting to find the resistance vavlues of resistors R19 and R36. Thanks |
| Back to top |
