DIYnot
Local | Network
   DIYnot > Forums
Local | Network
re-alarm going off on tamper
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Sun Sep 13, 2009 10:09 am Reply with quote
Hi, I posted a question a month ago, and Whistle gave me advice. Since then I have the same problem, IE, alarm goes off and registers "tamper" however it resets immediatly every time. Today,its done it 4 times, having changed the battery as Whistle advised.It always goes off when I use light switch near control box, and it can then do it several times afterwards as today, within minutes of each reset.I somehow still think the light switch has something to do with it?It has gone a month since it last occurred and battery change.I have a PIR near the swich, but have changed that also.Any ideas gratefully recieved,as it resets imediately, i cannot trace fault.
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 947 times
PostPosted: Sun Sep 13, 2009 2:25 pm Reply with quote
Have you got any cables under the carpet near the light Switch?
You may be causing said Tamper fault by walking on the carpet near a damaged cable underneath?
(I used to Work for Lander Alarms Years ago and came across this more than once!) icon_wink.gif
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Sun Sep 13, 2009 5:28 pm Reply with quote
Hi, No.This has been off and on for a while.The switch cable goes up the wall in trunking, right by PIR, then to strip light. My control panel is on wall 4 feet away, all in garage.My next task is eliminate strip light? It always starts when switch is activated, the alarm is activated, resets immediately, then may,as today go off again 3 times without using the switch, then settles down for sometimes a month or so.Bit of a poser;no bare cables at all.thanks
Back to top
 Alert Moderators
youtekkinthepish
from Bhutan
PostPosted: Sun Sep 13, 2009 5:49 pm Reply with quote
To clarify.
Light off, switch left alone, = no problems.
Switch used - possible FA problems.
Light left on , switch not used - problem keeps occuring?
With the switch wire close to the PIR, Possible noisy strip light?
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Sun Sep 13, 2009 6:03 pm Reply with quote
youtekkinthepish wrote:
To clarify.
Hi, Before today , switch used frequently, no problem.Changed battery, old one ok.!! today, activated switch on, alarm activated immediately. reset alarm, ok.switched light off, alarm activated 1 minute later.reset again.2 mins later,, alarm activated, not touched switch, reset again, repeat one more time.No more problems all day, swith been on & off frequently.This is the usual sequence of events every several weeks/months.May not occur again until another 4 weeks or so?
Back to top
 Alert Moderators
slowdown
from Unknown or unspecified country
PostPosted: Mon Sep 14, 2009 6:40 pm Reply with quote
yes its your light - flurescents are well know for it.
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Tue Sep 15, 2009 11:30 am Reply with quote
Hi, I have taken tube out, see if that solves it. What does a strip light do to affect the tamper circuit? Would I be better replacing it completely with ordinary bulpb, replace starter, or what? I have always suspected the lighting circuit as it always starts with the light switch. What confuses me though is why does it happen, then go for weeks ok then happen again. The switch is used every day several times a day.Why the intermitency? thanks for reply, let you know the outcome
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Fri Sep 25, 2009 12:05 pm Reply with quote
Hi Guys, Update. problem still there. changed battery and taken strip light out and replaced with normal fitting.Same thing happened today, as soon as I activated the light switch, of whichthere are 2, 2way, alarm went off on tamper again. reset immediatly.Baffled.any ideas?
Back to top
 Alert Moderators
slowdown
PostPosted: Fri Sep 25, 2009 3:23 pm Reply with quote
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 856 times
PostPosted: Fri Sep 25, 2009 5:38 pm Reply with quote
Is one of your switches arcing? Maybe causing a spike that upsets the microprocessor?
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Fri Sep 25, 2009 5:57 pm Reply with quote
Hi,Thanks for input, it isn,t the strip light, as I said, i have replaced it, regarding the switch arcing, it can occur using either of the 2 switches, 2way in garage.The switches are definely connected somehow as it always starts with activating either of the 2 switches.I have checked switches visually, seem ok? As the light switch cable runs up the wall inside its plastic cladding ,it runs adjacent a PIR, I wonder if that has any effect? Certainly is a poser.If only it wouldn,t reset immediately. I could try and trace it.open to any advice.try anything.cheers
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 856 times
PostPosted: Fri Sep 25, 2009 6:00 pm Reply with quote
You could do with trying a different PIR. If it is a cheapy it won't have very good RFI protection. Or maybe the panel doesn't have that micro delay that is there to stop this happening.
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Fri Sep 25, 2009 6:10 pm Reply with quote
Hi Joe can you elaborate about the board.Or Panel. not sure what you mean? My next job 2moro was to either resite the PIR, I can change it, have a spare.cheers
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 856 times
PostPosted: Fri Sep 25, 2009 6:16 pm Reply with quote
The detection (normally closed) circuits of an alarm should have a 400 - 500 millisecond delay before it 'reads' a circuit as open. If you open and close the circuit really quickly the open circuit won't register. The reason for that is that voltage spikes and fluctuations can trigger an alarm falsely, so this tiny half second delay was added. That's why panic buttons are latching.
Back to top
 Alert Moderators
joesoap1
from United Kingdom
Thanked: 3 times
PostPosted: Fri Sep 25, 2009 6:22 pm Reply with quote
OK,got that. If panel hasn,t got the delay, what,s cure apart from changing panel, didn,t put a panic button in . I installed it myself 14 years ago, been fine till lately pir is a pyronix coltxs uk made.is that a cheapie?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Pyronix Sterling 10 Alarm - Tamper Message 4 120 Sat Jan 18, 2014 4:09 pm
C+K Securitech alarm tamper help (pics included) 4 140 Tue Aug 21, 2012 2:29 pm
Unknown veritas alarm - tamper battery removed 19 300 Mon Dec 16, 2013 11:10 pm
my optima xl6 house alarm wont come out of tamper mode. 2 240 Mon Jan 10, 2011 9:35 pm
Veritas 8 alarm tamper red light 6 100 Fri Jan 23, 2015 8:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
