DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Baxi Duo Tec question
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Craig8701
from United Kingdom
PostPosted: Fri Sep 18, 2009 6:07 pm Reply with quote
Hi people, a quick question for those familiar with this boiler, i just recently had a baxi duo tec 24he fitted and want to know how i can have hot water only without the central heating kicking in.
There are only 3 options on the controls, OFF/HOT WATER & CH/RESET. iv put the temp of the CH down to the lowest it will go which is 25c but in order to have hot water on demand you have to have the CH on as well which very annoying as its constantly making a humming noise and occasionally fires up.
Any ideas? my previous boiler and a control which only fired the boiler up if needed you hot water, CH or both. i don't want to keep switching it on and off when i need it for hot water.
Craig
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 895 times
PostPosted: Fri Sep 18, 2009 6:19 pm Reply with quote
icon_confused.gif combi, means hot water on demand wich over rides ch demand.if recently installed then id get the installer back to show you the controls. as this is good practice done by a rgi when works beeen completed.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Fri Sep 18, 2009 6:26 pm Reply with quote
programmer / timer icon_question.gif
Back to top
 Alert Moderators
baxpoti
from United Kingdom
Thanked: 555 times
PostPosted: Fri Sep 18, 2009 6:34 pm Reply with quote
Building regs part L specify a boiler interlock is required.
You either haven't got one or you don't know how to use it.
Refer back to your installer
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Fri Sep 18, 2009 6:59 pm Reply with quote
Part of the boiler installation is to explain the controls properly, which clearly has not been done.
Get him back to solve the problem.
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3207 times
PostPosted: Fri Sep 18, 2009 7:38 pm Reply with quote
Back to top
 Alert Moderators
Craig8701
from United Kingdom
PostPosted: Sat Sep 19, 2009 11:31 am Reply with quote
Thanks for the repllies so far, He did go through the controls and said it stays on because of the frost protection. however after the reading the manual that only comes on if the boiler drops below 5c. im guessing its something to with the boiler interlock, can some one shed some light on this and how it can be sorted??
Craig
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Sep 19, 2009 12:02 pm Reply with quote
The roomstat is the interlock
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 380 times
You should have a timer? Plugged into the boiler maybe?
You should also have a thermostat on the wall.
Turning either of these down or off will prevent heating coming on.
If you have neither then get him to fit them!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Sat Sep 19, 2009 12:09 pm Reply with quote
It sounds to me as if he may have wrongly wired it !
Is he a bona fide registered installer?
What you have is not correct although I am not totally confident that you necessarily know how to control it!
Does it have a timeclock?
Does it have a room stat?
Tony
Back to top
 Alert Moderators
Craig8701
from United Kingdom
PostPosted: Sat Sep 19, 2009 12:13 pm Reply with quote
There is a mechanical clock timer fitted which is set to off but doesnt seem to switch the boiler off. there is a room thermostat which was set to the previous boiler but isnt hooked up to the new one. is there a way to connect the old one up or will a new one be required? i cant see how the old one was connected as i recently bought this house and the previous owners took the old boiler with them which was a condensing one. iv had it converted to combi.
Craig
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Sep 19, 2009 12:34 pm Reply with quote
Craig8701 wrote:
... i recently bought this house and the previous owners took the old boiler with them ...
Honestly, how sad can you get?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Sat Sep 19, 2009 12:41 pm Reply with quote
Was it declared at the contract stage that they were taking the boiler with them?
They are classed as part of the house and should not be just taken with them!
They can take light bulbs and one seller did that to me! Miserable tight ....
Tony
Back to top
 Alert Moderators
Craig8701
from United Kingdom
PostPosted: Sat Sep 19, 2009 12:44 pm Reply with quote
it was a repo so bought as seen, they more or less took everything including the lights and the fireplace!
Back to top
 Alert Moderators
gilly1807
from United Kingdom
PostPosted: Mon Oct 12, 2009 2:23 pm Reply with quote
There are only the controls you said (OFF/HOT WATER & CH/RESET) on the Duotec and the temp control only goes down to 25c.
I've spoken to Baxi technical about this because I paid extra for the built in digital clock and this has no off facility on it. (rip off)
They told me that I should have a room stat and you would turn off the boiler by turning off at the room stat preventing central heating mode firing up un-necessary in the summer time.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
A Basic Plumbing Question (Baxi Combi 105 HE) 2 540 Sun Aug 17, 2008 10:18 am
Question about Automatic Air Vent on Baxi HE133 Plus 8 760 Sun Nov 18, 2007 5:21 pm
Baxi 105 HE Boiler Timer Question. 3 1480 Mon Dec 22, 2008 8:07 pm
BAXI System 35/60 problem and question! 4 600 Sun Aug 17, 2008 11:52 am
Baxi back-boiler question 20 1600 Thu Nov 22, 2007 3:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
