DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Combi Boiler and turning off water supply
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
OhGranny
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 20, 2009 7:43 am    Post Subject:
Reply with quote Thanks
Hi
I have been doing some work on my bathroom and have had to turn the water supply off a few times.
Now when I turn on the cold tap the boiler pump (or something inside) operates for a few seconds the pressure drops to .8 then goes back up to 1 bar. The boiler doesn't ignite but something runs inside. It never used to do this before!
I have always turned the boiler off when the water supply was off in case someone turned the hot water tap on accidently but I have never turned off the water supply to the boiler.
The boiler still give hot water but I am a bit worried now that something is running inside when I turn on the cold water tap. Something has changed.
I have a manual but can't see any advice or procedure to follow if disconnecting the water supply.
Any ideas or advice please?
G.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 7:54 am    Post Subject:
Have you fitted mixer taps, or created a dead leg somewhere in the pipe work.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sun Sep 20, 2009 8:12 am    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 8:30 am    Post Subject:
It's obviously a combi, so any air can only be trapped in a dead leg.
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sun Sep 20, 2009 8:33 am    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 8:35 am    Post Subject:
Come on kev, you've got to assume that he's ran all his taps plenty, after doing new work and before posting on here.
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 8:36 am    Post Subject:
and stop editing your posts you b*****r.
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sun Sep 20, 2009 8:38 am    Post Subject:
never assume anything on here
have you turned the selector to water / heating
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 8:40 am    Post Subject:
Back to top
 Alert Moderators
OhGranny
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 20, 2009 8:47 am    Post Subject:
Thanks lads that's put me at ease a bit at least the boilers not K********d.
I've got the bath out at the moment to plaster so the taps hadn't been run the bath pipes had air in.
I undid the taps and a large gush of air came out the combi seems O.K.
In future should I turn off the water supply to the combi boiler when I turn off the water?
G.
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 8:50 am    Post Subject:
No need if you turn off the water at the stopcock anyway.
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sun Sep 20, 2009 9:15 am    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sun Sep 20, 2009 9:34 am    Post Subject:
That's what I like about you kev, you're so subtle and debonair. icon_razz.gif
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 49 times
PostPosted: Sun Sep 20, 2009 9:37 am    Post Subject:
__________________
A rolling stone gathers no moss.
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sun Sep 20, 2009 9:38 am    Post Subject:
yup and we have all been caught out at sometime
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Turning of central heating water supply? 2 100 Thu Feb 26, 2009 9:58 pm
Turning off water supply to change w/c & sink 3 220 Sun May 17, 2009 9:50 am
Turning off hot water supply 3 260 Mon Jul 02, 2007 11:25 pm
tap washers / turning off the water supply 2 520 Wed Mar 07, 2007 12:04 pm
turning off hot water supply 5 440 Tue Apr 26, 2005 3:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
