can't fit downlighters back into ceiling properly
4 Aug 2006
Powys
Hi- removed downlighters in the hall and landing so the ceilings could be replastered but am now struggling to refit the downlights. They are the standard design with the pair of clips (each clip consisting of one long and one short component) but there is no tension in the clips to work against- has another component 'pinged' off when I removed the downlights?, if so is it easy enough to get a replacement, or am I just missing some way of adjusting the fit of the clips to get them under tension?.
Cheers
does that help ?
Loving the diagram! Feel like a bit of a dullard now but I'm sure it won't be the last time that I order humble pie from the menu.
Thanks for your time- you should consider going into instruction leaflet design (I'm sure if my electrician had left the leaflet for my downlights they wouldn't have been as easy to follow and I would probably have had to post on the forum anyway).
Going to put them all back up now and pretend to the Wife that I worked it all out myself, if you don't mind.
Cheers again.
It was a diagram shown on an old DIYnot post- I didn't draw it, just 'borrowed' it from some kindly person that did draw it.
Whoever you were (Mr Aritist) you've left a legacy :)
