Danfoss 103E Timeswitch
21 Sep 2009
West Midlands
This combi boiler timer lost all indication of the clock, hence it does not work, except that it shows the red "on" light.
Any one can help as to how I can fix it?
Replace it would be the usual course of action.
If you know an electronics expert then he might be able to repair it.
Its probably only the back up battery failed.
A new unit is normally the best option though.
Tony
Used to be able to get a factory replacement unit (FRU) for the 103
Sorry, I should have said that the back up battery is usually soldered in place.
However, in the electronics world, batteries are available with solder tags.
Tony
Press PROGRAMME once
􀁒 Use + and – buttons to set the
correct time
􀁒 When time is correct press
PROGRAMME again.
