| Author |
Message |
pj11
Joined: 27 Nov 2007 Posts: 31 Location: United Kingdom Thanked: 1 time
Posted: Tue Sep 22, 2009 8:55 pm |
Has anybody had any experience with a citreon picasso 2.0 hdi engine (diesel),having intermittent non start/cutting out fault. Changed the fuel pump in the tank about 2 months ago, run fine.But has now decided to not start /cut out again. Towed home by AA, who couldnot get it going, but left with no low fuel pressure, fault code.Checked out the fuel system appeared to be no fuel from tank to filter(pump not working?) fiddle around with electrics in engine bay,checked out fuel filter,it started ,no problems,no warning lights on.Since it has cut out and restarted intermittently on several occasions.Is there a fuel pump relay fitted ? i suspect the fuel pump is losing its feed. Any help appreciated. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
ch427
Joined: 16 Jan 2006 Posts: 2087 Location: Cardiff, United Kingdom Thanked: 166 times
Posted: Wed Sep 23, 2009 6:14 pm |
a friends peugeot with this engine has a similar problem but his struggles to start,there is a pressure valve on the fuel system in the engine bay somewhere that plays up. Hes taken it to a local diesel specialist this week so i will ask him what they found |
| Back to top |
The following user says thank you to ch427 for this useful post:
pj11 (11 Oct 2009) |
| Alert Moderators
skippster76
Joined: 09 Jul 2005 Posts: 238 Location: Birmingham, United Kingdom Thanked: 26 times
Posted: Sun Sep 27, 2009 11:13 pm |
You might find it might be what i call a multifunction relay, which is normally brown in colour and is located under the bonnet on either flitch. It slots in to a black plug with a red locking device. When it fails to start try giving the relay a tap and see if it starts. |
| Back to top |
The following user says thank you to skippster76 for this useful post:
| Alert Moderators
gregers
Joined: 28 Mar 2008 Posts: 4102 Location: Sussex, United Kingdom Thanked: 276 times
Posted: Mon Sep 28, 2009 8:25 pm |
| Back to top |
The following user says thank you to gregers for this useful post:
| Alert Moderators
pj11
Posted: Sun Oct 11, 2009 11:48 am |
| pj11 wrote: | | Has anybody had any experience with a citreon picasso 2.0 hdi engine (diesel),having intermittent non start/cutting out fault. Changed the fuel pump in the tank about 2 months ago, run fine.But has now decided to not start /cut out again. Towed home by AA, who couldnot get it going, but left with no low fuel pressure, fault code.Checked out the fuel system appeared to be no fuel from tank to filter(pump not working?) fiddle around with electrics in engine bay,checked out fuel filter,it started ,no problems,no warning lights on.Since it has cut out and restarted intermittently on several occasions.Is there a fuel pump relay fitted ? i suspect the fuel pump is losing its feed. Any help appreciated. |
Thanks for your help. I replaced the engine management double relay cost £12, around three weeks ago (1000miles approx), no fault , touch wood! . So if you experience a similar fault, for the cost of the relay i would try this,it a 2 minute job. |
| Back to top |
pj11
Thanks for your help. I replaced the engine management double relay cost £12, around three weeks ago (1000miles approx), no fault , touch wood! . So if you experience a similar fault, for the cost of the relay i would try this,its a 2 minute job. |
| Back to top |
mwf66
Joined: 03 Jan 2011 Posts: 9 Location: Manchester, United Kingdom
Posted: Mon Jan 03, 2011 1:58 pm |
| pj11 wrote: | | pj11 wrote: | | Has anybody had any experience with a citreon picasso 2.0 hdi engine (diesel),having intermittent non start/cutting out fault. Changed the fuel pump in the tank about 2 months ago, run fine.But has now decided to not start /cut out again. Towed home by AA, who couldnot get it going, but left with no low fuel pressure, fault code.Checked out the fuel system appeared to be no fuel from tank to filter(pump not working?) fiddle around with electrics in engine bay,checked out fuel filter,it started ,no problems,no warning lights on.Since it has cut out and restarted intermittently on several occasions.Is there a fuel pump relay fitted ? i suspect the fuel pump is losing its feed. Any help appreciated. |
i think I have the same problem on an 2003 2.0l HDI can you tell me where this relay is and what it looks like as mine has been off the road for 2 months now and it is very frustrating. |
| Back to top |
pj11
Posted: Mon Jan 03, 2011 8:16 pm |
Hi the relay is located on the right hand bulk head , is brown in colour
and cost about 12 quid.
Have you checked if your fuel pump(in fuel tank) is running ok, with ignition switched on you can hear you fuel pump run for a few seconds and the filter housing pressurise. You could also disconnect the fuel filter inlet pipe then switch on ignition fuel should flow from pipe(stick a bag over end to catch fuel),if not tap bottom of fuel tank to get pump going this is a very common faut with hdi engines,the pump wears and metal filelings contaminate the filter. |
| Back to top |
mwf66
Posted: Mon Jan 03, 2011 8:50 pm |
| pj11 wrote: | Hi the relay is located on the right hand bulk head , is brown in colour
I cant see a brown relay or any relay on my bulk head, the pump runs until the engine cuts out then you cant hear it running, unless you leave it a few minutes then try it again,it does sound a bit squeeky when running, otherwise you just hear it clicking. |
| Back to top |
mwf66
Posted: Tue Jan 04, 2011 2:19 pm |
| mwf66 wrote: | | pj11 wrote: | Hi the relay is located on the right hand bulk head , is brown in colour
hi is the relay in the engine bay bulkhead or on the inside drivers bulkhead behind that pull out panel? |
| Back to top |
skippster76
Posted: Tue Jan 04, 2011 6:53 pm |
This is the relay but it may have a brown top.it will be on the nearside bulkhead or the offside inner flitch.(under bonnet) |
| Back to top |
mwf66 (5 Jan 2011) |
| Alert Moderators
mwf66
Posted: Wed Jan 05, 2011 7:15 pm |
| skippster76 wrote: |
does anyone know where is the best to get one? BMS, CITROEN, HALFORDS ect |
| Back to top |
skippster76
Posted: Wed Jan 05, 2011 7:28 pm |
Main dealer Citroen/Peugeot depends what you have. |
| Back to top |
mwf66
Posted: Wed Jan 05, 2011 7:35 pm |
brilliant thanks skipster  |
| Back to top |
mwf66
Posted: Thu Jan 06, 2011 7:45 pm |
| mwf66 wrote: | | skippster76 wrote: |
mine seems to totall different, it has 2 high voltage cables going in the bottom and a green multi plug! and its black all over apart from the underneath, any ideas anyone?
look in my album theres 4 pic's of it. dont know how to load them on here! |
| Back to top |
