DIYnot
Local | Network
   DIYnot > Forums
Local | Network
fitting a log burning stove
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
matt9714
from United Kingdom
PostPosted: Wed Sep 23, 2009 6:59 am Reply with quote
I plan on installing a log burner into the existing fireplace. Someone has already mounted a steel plate with hole for 5inch flue. Are there various regulations i will have to follow like with installing a gas fire or can i just go ahead myself?
Back to top
 Alert Moderators
Goldspoon
from United Kingdom
Thanked: 33 times
PostPosted: Wed Sep 23, 2009 7:05 am Reply with quote
Yes.
Here's a good place to start: http://www.stovesonline.co.uk/stove_building_regulations.html
Stove should be fitted by a Hetas registered person or you can do it yourself by notifying your local building control before you start (125 ish)
Key things to watch:
Hearth construction and size.
You will need an air vent fitting to the room if stove more than 5KW
Back to top
 Alert Moderators
RigidRaider
from United Kingdom
Thanked: 44 times
PostPosted: Wed Sep 23, 2009 7:45 am Reply with quote
The quality and conditon of the flue are very important. Make friends with your chimney sweep; he will advise you about flue and cowl and he will install the stove with a port for easy sweeping in future years. He won't thank you if there's no port.
After the flue your arrangements for storing and seasoning the wood are equally important. You need a sheltered well-ventilated place where you can store it, ideally for a year but a full summer is okay if you buy it very early in the year part-seasoned.
If you have a choice of sizes of stove, opt for the smaller one; you will need to burn it a little harder and it will burn cleaner as a result. Nothing is worse than a smoky yellow flame in a shut-down oversize stove.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Wed Sep 23, 2009 7:55 am Reply with quote
In addition to Goldspoons link, you also need to look specifically at Part J of the Building Regs. &, depending on the type of flue you currently have, you may need a new class 1 flue liner.
Follow correct procedure as you will need to produce either a HETAS certificate or a certificate of compliance from your LABC when you come to sell the property.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitting wood burning stove 6 1660 Sun Jan 08, 2006 12:53 am
Fitting a wood burning stove 2 1580 Tue Mar 25, 2008 11:39 pm
Fitting log burning stove 13 580 Sat Jan 07, 2012 8:24 pm
Wood burning stove with back boiler open vented link up 6 300 Wed Mar 09, 2011 11:04 pm
wood burning stove installation 2 120 Fri May 13, 2011 7:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
