DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing Plasma TV onto stud partition wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
JoinerMike
from United Kingdom
PostPosted: Wed Sep 23, 2009 9:23 pm Reply with quote
Hi all. A question for my fellow joiners.
I have recently being asked by a customer to fix a bracket to a stud partition wall for a plasma which is a monstrous 5ft wide 35 inch high and 70kg's in weight. The only way I can think is to strip the plasterboard off one side of the wall. Fix more 4"x2" framework, re-plasterboard and skim the wall.
I can't think of any other options. Any joiners who have tackled this sort of task in a different way? If so please tell me.
Mainly due to wall having very old plater coving and plaster daedo rail, which i don't fancy trying to match back up to.
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 48 times
PostPosted: Thu Sep 24, 2009 7:33 am Reply with quote
How about fitting some steel strips (say 5mmx50mm) between studs on the surface and fixing the TV bracket to tapped holes in that.
Painted the same colour as the bracket (or the wall) it will be hidden behind the TV and not push it out very far from the wall.
Back to top
The following user says thank you to IJWS15 for this useful post:
JoinerMike (24 Sep 2009)
 Alert Moderators
JoinerMike
from United Kingdom
PostPosted: Thu Sep 24, 2009 11:02 am Reply with quote
Good idea. Didn't even think of tackling it that way. Doing it this way i could use metal or even a plywood sheet. Bolt the bracket to the plywood/metal then screw this into the studwork so the weight is spread across as many studs as possible. Cheers mate. Knew someone would give me a different view. Give yourself 10 points icon_lol.gif
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 226 times
PostPosted: Thu Sep 24, 2009 11:13 am Reply with quote
Whilst not of that size or weight. I wanted to fit an LCD tv to a lathe & plaster wall, the back side of the wall was in a cupboard so I could get to it.
I bolted 2 pieces of ply, 1 each side of the lath & plaster wall, I then fitted the tv barcket to the ply.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
False chimney breast for gas fire and plasma 3 6820 Thu Feb 17, 2005 5:35 pm
soundproofing a stud wall partition???? 9 1860 Sat Nov 06, 2004 8:19 pm
Porthole window in stud partition 2 100 Wed Jun 13, 2012 8:51 am
Securing a safe to partition wall 10 1160 Sat Feb 14, 2009 6:51 pm
Sliding doors/partition wall - how big can the panels be? 9 960 Tue Mar 25, 2008 3:35 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
