DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Toilet overflow/outlet pipe leaking o
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Maggie123
from United Kingdom
PostPosted: Sat Sep 26, 2009 3:00 pm Reply with quote
Hello
I have noticed a small amount of water leaking around the overflow pipe from my toilet cistern. The water isn't going above the overflow pipe when it refills, the leak appears to be on the join (plastic bolt thingy) on the pipe. I have tried to tape it up with electric tape but it's still leaking - was hoping not to have to call a plumber at for what seems like a reasonably small job - any ideas please?
Maggie
Back to top
 Alert Moderators
Goldberg
from United Kingdom
Thanked: 42 times
PostPosted: Sat Sep 26, 2009 3:22 pm Reply with quote
I take it that the overflow pipe is connected at the base of the cistern?
1. Stop water from entering the cistern.
Hopefully you will find a service valve nearby.
2. Flush the cistern, then sponge out the rest of the water.
3. Uncouple the overflow pipe, and then undo the nut that attaches the overflow tube to the cistern, and remove it.
4. Thoroughly clean and dry all mating surfaces.
5. If the rubber washer is disintegrating, renew it.
6. Reinstall the overflow tube and tighten the nut.
7. Reattach the overflow pipe.
8. Refill the cistern and test your work.
9. Thank anyone on the forum who you feel helped you.
Back to top
 Alert Moderators
Maggie123
from United Kingdom
PostPosted: Sat Sep 26, 2009 3:35 pm Reply with quote
Thank you!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Washing machine outlet TO Cold water overflow outlet. 5 100 Wed Sep 14, 2011 1:48 pm
Toilet leaking by the outlet pipe 7 780 Tue Aug 07, 2007 7:02 pm
leaking toilet outlet pipe 3 2740 Sat Oct 08, 2005 2:37 pm
Large cap between toilet outlet and waste pipe 8 1200 Fri Jun 02, 2006 10:21 am
Toilet Leak - replacing outlet pan/pipe 2 340 Mon Aug 17, 2009 12:35 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
