DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal Isar HE35 - DHW ok, no CH
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
RayLee
from United Kingdom
PostPosted: Sat Sep 26, 2009 5:27 pm Reply with quote
Another dreaded Isar HE 35 from what I've read on forums. It's just over 3 years old, using an original black PCB. Already had a replacement expansion vessel under warranty.
Currently DHW is working fine but CH isn't.
As it's now getting chilly in the evenings, I thought i'd fire up the boiler for CH. Turned the timer on, waited 10 mins and checked all rads. no joy.
I thought it was a stuck TRV like last year but i think it's ok - Removed TRV head, pin doesn't look stuck and tapped the valve body a few times with a pin hammer.
Turning the boiler on (or switching from DHW to CH), I can hear a clicking/ticking sound which makes me believe it's the diverter valve/actuator at fault. The burner does fire up though for CH for about a minute or so until it goes off. I assume overheat protection?
Switching from CH to DHW, same ticking noise and the burner doesn't fire until the ticking has stopped.
So, anything else I can rule out before getting a parts/engineer to fix?
On another subject, if I got the Ideal fixed price engineer to come and fix, would they also replace the PCB to the new orange ones when my current one isn't faulty?
Cheers all.
Ray
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1134 times
PostPosted: Sat Sep 26, 2009 6:04 pm Reply with quote
Very likely. Not too hard to change .
Re the pbc, it would depend whether it had had an "accident" or not. icon_wink.gif
Back to top
 Alert Moderators
corgikiller666
from United Kingdom
Thanked: 17 times
PostPosted: Sat Sep 26, 2009 6:18 pm Reply with quote
before anything else are you sure you have no dripping hot taps or leaking hw pipes?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3616 times
PostPosted: Sat Sep 26, 2009 6:21 pm Reply with quote
You can easily prove the latter by turning off the cold feed into the boiler.
If that does not solve the problem then it does sound like a jammed/failed diverter valve.
Tony
Back to top
 Alert Moderators
RayLee
from United Kingdom
no leaking/dripping taps. always displays 0 unless i'm using the HW (d) or CH (c)
Back to top
 Alert Moderators
swiftyboy
from United Kingdom
PostPosted: Thu Mar 04, 2010 12:56 pm Reply with quote
I too have the same problem, I have DHW no CH with the control displaying 0, I have just replaced the PCB to the newer orange on and fitted the pins in the correct order ( confirmed when switching on I get a 4 displayed for 1-2 seconds )
I dont seem to have any leaks anywhere and all the radiators have been bled, how can I checked the divertor valve to see if it has stuck or jammed
getting very cold up here now any help would be very much appreciated.
cheers
Back to top
 Alert Moderators
onlyfitidealboilers
from United Kingdom
Thanked: 151 times
PostPosted: Thu Mar 04, 2010 5:56 pm Reply with quote
Back to top
 Alert Moderators
Temprise
from United Kingdom
Thanked: 58 times
PostPosted: Thu Mar 04, 2010 6:53 pm Reply with quote
Does the boiler always show 0 in the display, even when your external timers and room stat are on and calling for heat?
If this is the case then you will have a problem with your external controls (faulty timer, room stat or wiring problem).
Regards.
Back to top
The following user says thank you to Temprise for this useful post:
swiftyboy (5 Mar 2010)
 Alert Moderators
nogoodatfaultfinding
from United Kingdom
Thanked: 72 times
PostPosted: Thu Mar 04, 2010 7:12 pm Reply with quote
Regards.
First thing i would check as well in this situation
Back to top
 Alert Moderators
Garfeild
from United Kingdom
Thanked: 130 times
PostPosted: Thu Mar 04, 2010 11:00 pm Reply with quote
6 month old thread
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ideal isar he35 inital startup / connection 18 1360 Tue Feb 15, 2005 2:14 pm
Ideal Isar HE35 Fault 8 400 Fri Oct 15, 2010 12:57 pm
Ideal Isar HE35 no hot water or heating 2 60 Fri May 03, 2013 8:08 am
Ideal isar He35 7 560 Fri Apr 17, 2009 6:11 pm
IDEAL ISAR HE35 BOILER-HEAT BUT NO HOT WATER-HELP REQUIRED! 13 4620 Mon Dec 24, 2007 1:04 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
