DIYnot
Local | Network
   DIYnot > Forums
Local | Network
joining epdm to existing felt roof?
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
pmr1983
from United Kingdom
PostPosted: Tue Sep 29, 2009 7:45 pm Reply with quote
i have a garage roof to do with epdm which is joined to next doors garage which has been recently felted what is the best way to join them down the middle?
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 162 times
PostPosted: Tue Sep 29, 2009 8:14 pm Reply with quote
Are you boarding over your existing felt or slicing the felt between the two roofs and removing the felt your side, then reboarding?
Back to top
The following user says thank you to Mw Roofline for this useful post:
TPDLtd (27 Apr 2010)
 Alert Moderators
pmr1983
from United Kingdom
PostPosted: Wed Sep 30, 2009 10:53 am Reply with quote
i will be removing the felt from my side then reboading
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 162 times
PostPosted: Wed Sep 30, 2009 5:25 pm Reply with quote
EPDM is best stand-alone and not joined to a felted roof. This isn't the way they tell you to do it on the EPDM course, but its what the lads do.
As long as you have done a perfect clean straight slice between the two roofs, before you lay your board down 1st glue some rubber down overlapping a foot under and foot over, then screw the board down tight, screwing well near the edge. Your board must be butted hard against the straight cut felt.
Run a bead of leadmate or lead sealant between the wrapped around rubber and the felt edge. Let it dry whilst u board the rest of the roof. Don't use silicone!
Then you lay the rubber as normal overlapping onto the felt slightly and then seal it again with lead mate.
Finally you then put a length of epdm seam tape over the join and then onto the other roof, use water based glue as the solvent stuff reacts with the oils in the felt. the other roof has to be as clean and dry as poss.
You shouldnt really join rubber to felt, its an absolute pain and only do it if the join is at the highest point on the fall.
See my excellent drawing, lol (which doesnt show final seam tape join)
Back to top
 Alert Moderators
pmr1983
from United Kingdom
PostPosted: Wed Sep 30, 2009 10:43 pm Reply with quote
hi thanks for the advise, there is hardly any fall if any on the roof it's flat and i will also be removing the old boards (rotten) so the new boards will be just below nextdoors felt level with there boards so they wont quite but up to the felt like your picture shows does this make any difference or will this method still work?
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 162 times
PostPosted: Thu Oct 01, 2009 7:17 am Reply with quote
It will work if you take your time. Is there anyway the neighbours can have it done? Maybe if you cost up the materials and pay yourself £150 then its a bit of extra money for your work but then at least you have peace of mind. icon_smile.gif
Back to top
 Alert Moderators
SurreyRoofingEstimator
from United Kingdom
Thanked: 64 times
PostPosted: Thu Oct 01, 2009 1:37 pm Reply with quote
Best way is as has been said before, get neighbour to have theirs done and save a bit of money in the long run.
One way around it that we have been informed of for the membrane we use (Rhepanol fk) is to apply a liquid coating system (Sealoflex) at the join. These two products are supplied by the same company (SIG) and is covered under their warranty.
Back to top
 Alert Moderators
Zeberdee
from United Kingdom
Thanked: 4 times
PostPosted: Tue Feb 08, 2011 11:53 pm Reply with quote
Hi MW Roofline!
Why do you use that way to join the roofs?
What effect does it have?
Cheers
Tony.
Back to top
 Alert Moderators
datarebal
from United Kingdom
Thanked: 102 times
PostPosted: Wed Feb 09, 2011 7:13 am Reply with quote
I would say this could end in tears..
your best chance of sucess is to put a 2x2 where the join is going to be torch on some felt flashings over this that sorts your neighbour, then do you one ply.
Back to top
 Alert Moderators
davecrouch
from United Kingdom
Thanked: 2 times
PostPosted: Wed Feb 09, 2011 7:48 pm Reply with quote
you can do this and it will work! its not ideal i have to say, but we have done quite a few epdm to felt roofs. (and we have not had a come back yet) the best way i have found is to replace your boards, glue down your rubber system, leaving a six inch overlap over the felt roof. make sure the felt roof is dry (we use a hairdryer that we have just for this purpose!). remove all loose dirt, dust and grime. you will then need a tin of acrypol fibre based resin. put plenty down on the felt side, not the rubber. build up a thick layer across the six inches where the rubber will sit. then lay the rubber down on to it, and press in. you will then need a length of slate batten (the thicker one). this needs to be screw fixed down to hold the rubber tight down. make sure its firmly fixed, certainly more so at the back of the roof where it pitches (i presume its a dormer?). the acrypol will push out and form a superb seal. then paint over the batten with the same material to protect it fromm rot. job done.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 728 times
PostPosted: Fri Feb 11, 2011 9:34 am Reply with quote
following the Acrypol answer - Have a look @ liquid plastics website - they sell similar, maybe better icon_confused.gif stuff . Thanks to all the guys who replied - I`m still learning about this flat roofing, in preparation for mine over the kitchen - yes I could do it in lead, but it`s a bit pricey and heavy icon_wink.gif and it might not stay long
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Joining EPDM to mineral felt. 4 100 Wed Aug 24, 2011 4:10 pm
Flat felt roof joining with tiled roof 2 960 Fri Nov 18, 2005 12:00 pm
Joining a roof to an outside roof 3 120 Wed Jan 12, 2011 9:53 pm
Flat roof insulation at edges and joining neighbours roof 7 100 Wed Apr 10, 2013 1:14 pm
Joining terrace roof gap?! 2 660 Thu Jun 08, 2006 9:37 pm
DIYnot
