DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ferroli domina 80 - tech help needed
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
paulsx
from United Kingdom
PostPosted: Wed Sep 30, 2009 8:48 am Reply with quote
Hi. I ahve a ferroli domina 80 combi that wont fire up in either CH or HW mode. The demand lights come on but the boiler refuses to fire. I have checked the manual and followed the diagnostics in it.
There is 230volts being passed from the main pcb to the igintion pcb. The low water pressure switch is working ok. The aip pressure switch also seems to be switching if you apply a positive pressure to it. The overheat stat is also showing continuity.
I cant get into the fan easily to check that there is 230v present but i have checked it at the pcb end and there isnt anything.
Am i missing soemthing or has the ignition pcb died?
I know i should have a corgi guy in but the last one was useless. I will get the boiler gas saftey checked etc once i know it can be repaired as the parts look very expensive.
Thanks for any advice
Paul
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3602 times
PostPosted: Wed Sep 30, 2009 10:36 am Reply with quote
Paul
If there is no power at the PCB then I dont really think there is likely to be any at the fan !
Thats just as well you could not access the fan because you should not be opening the combustion chamber or fiddling with the air pressure switch.
It might be the PCB but further preliminary checks would be in areas which I cannot advise you about on account of safety issues.
Its going to be OK but you could check the resistance of the fan coil at the PCB end. They are usually about 48 ohms.
Unless anyone else has any suggestion of yuo you can safely do the advice is to get a competent gas registered engineer who repair boilers rather than just installing them.
Tony
Back to top
 Alert Moderators
paulsx
from United Kingdom
PostPosted: Wed Sep 30, 2009 12:03 pm Reply with quote
I know the fan is ok i have tested it separately. I meant i couldnt access the wiring in situ to check the supply but took it off to check the fan itself.
I understand the bit about getting someone to look at it but I am not a complete novice and to be honest dont want to pay the 300 that ferroli want to send someone out to look at it. If the boilers not worth reapairing i would rather find out now.
I have had 2 corgi registered guys look at it and they were both usless. It seems unless you have dealt with one of these before they can cause problems
The ferroli diagnostics sheet states if there is no voltage at the fan check the air switch. However the swtich wont operate if the fan isnt running so it can be that causing it. It's dead at the pcb end and I was hoping to confirm this before i take the board out and fault finding it as it's a ball ache
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3602 times
PostPosted: Wed Sep 30, 2009 12:21 pm Reply with quote
The APS does have to make a contact in the resting position!
However its probably the PCB but I would have checked everything else properly first as they are expensive.
Just being gas registered does not mean that anyone is able to diagnose faults on boiler.
British Gas probably do a fixed price repair for about 160.
An independent should not not be charging much more than we do! Most of our repairs are little more than 100 including parts.
Tony
Back to top
 Alert Moderators
paulsx
from United Kingdom
PostPosted: Wed Sep 30, 2009 1:15 pm Reply with quote
ok the APS is open circuit with the boiler at rest but demand on.
I'll try temporarly bypassing it and see if that cures the problem.
The 2 guys i used both clamed to be familular with these boilers etc but the first one blew the main fuse on the board and the 2ndd one wanted to randomly change bits until he found it.
Thanks for your advice
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ferroli Domina 80E Safety Valve 3 740 Mon Nov 01, 2004 8:56 pm
Pressure Drop on Ferroli Domina E 2 100 Thu Nov 11, 2010 3:34 pm
Ferroli domina 80e 2 280 Wed Jan 27, 2010 9:44 am
Ferroli Domina trouble 3 600 Mon Jan 05, 2004 9:51 am
Ferolli Domina 80E problem 8 120 Mon Jul 29, 2013 7:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
