Amana: Over-Sudzing?
16 Jan 2005
My Amana, large capacity washer (3.3cu/ft) tends to overflow with suds from the drain pipe during the rinse cycles. I know my drain is clear as I have flushed it several times and have not noticed any back-up. It's important to note that the overflow is not water,, just suds. I have tried halving the detergent & bleach, altering combinations of soap & water levels,, to no avail. The suds seem to appear after the water has been pumped through the drain,, after which the machine pumps just suds,, which do not drain properly and back-up through the drain pipe connection. Any advice??
Thanks.
Did you receive a reply to this post? I have the same problem. Thanks!
Thanks.
