Hi -
I have an old fuse wire-type Wylex fuse box which is situated in my garage, supplying sockets and lighting.
It also sends another cable out to my garden shed where it powers one double socket and a fused power switch for a pod pump.
After a lawnmower cable cutting incident (doh), one of the fuses blew and I rewired it.
However, while the garage power is functioning, the spur to the shed is completely dead.
I've changed the fuse in the shed switch, checked the connections in the shed and double checked all the wired fuses in the garage.
The wired fuse that failed is fairly dark blue on the securing screws - is this causing the problem - do these fail themselves even though properly wired?
Thank you in advance for any help or advice you may offer - I need to get the pond pump back up and running asap
Seej
Seej
