DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Drill bit stuck in drill chuck
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials
Author Message
MarkGregory
from United Kingdom
PostPosted: Sun Oct 04, 2009 12:25 pm Reply with quote
my drill bit is stuck fast in my drill chuck - any ideas on how to get it out?
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 158 times
PostPosted: Sun Oct 04, 2009 1:07 pm Reply with quote
A wee bit more information on the drill and chuck type would be helpful.
Back to top
The following user says thank you to Stivino for this useful post:
MarkGregory (6 Oct 2009)
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Sun Oct 04, 2009 4:25 pm Reply with quote
spray with wd40 and a little tap with a hammer normally works with screw type chucks. SDS is a bit more problematic
Back to top
The following user says thank you to Thermo for this useful post:
 Alert Moderators
big-all
from United Kingdom
Thanked: 957 times
PostPosted: Sun Oct 04, 2009 4:40 pm Reply with quote
some cheaper drills have a locking ring on the inside edge off the chuck where it faces the drill body icon_wink.gif
Back to top
The following user says thank you to big-all for this useful post:
 Alert Moderators
pompeyal
from United Kingdom
Thanked: 26 times
PostPosted: Mon Nov 09, 2009 1:39 pm Reply with quote
Sometime the chuck jaws lock up on the drill, usually on either cheap or very worn chucks, if you can loosten the chuck with the key then tap the end of the drill with a copper mallet, this should shock the chuck open. If this is the case then it would be a good idea to replace the chuck with a new one.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials All times are GMT
Page 1 of 1
Jump to:
Removing a stuck 18v drill chuck 3 100 Sat Jan 14, 2012 1:55 pm
B&D cordless drill - chuck stuck 3 1680 Tue Jul 29, 2008 8:21 am
Bosch Keyless Chuck - Stuck! Any ideas? 10 4940 Tue Jan 29, 2013 3:16 pm
how to retrieve drill bit stuck in the wall 5 280 Sat Dec 28, 2013 6:01 pm
Removing circ saw blade. Stuck! Help! 6 760 Sat Jan 06, 2007 2:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
