DIYnot
Local | Network
   DIYnot > Forums
Local | Network
the key in my mortise lock just keeps spinning
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
danormerod
from United Kingdom
PostPosted: Mon Oct 05, 2009 8:10 pm Reply with quote
hi
i cant open my back door. when i go to use the key in my mortise lock it just spins. i've looked for different advice and have been told by someone to slip a reciprocal saw over the lock and saw through it, and another person tells my that mortice locksw have a small catch within them that just needs flicking and the key will work again?????
i know i cant get to any screws to get the hinges off the wooden door.
can anyone help?
thanks
Dan
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 944 times
PostPosted: Mon Oct 05, 2009 8:41 pm Reply with quote
angle grinder to the hinge pins remove the pins and slip the door out
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Mon Oct 12, 2009 11:05 pm Reply with quote
What type of lock is it ? If its a BS rated lock, then it's likely the curtain will have failed, and isn't engaging the bolt to withdraw it. If you can see the bolt, you could try withdrawing it with a screwdriver whilst turning the key to open the lock.
Is your key intact - no broken bits?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Screws for door hinges just spinning. How to fix? 5 120 Sat Oct 25, 2014 10:51 pm
open door with lost keys to 5 lever mortise lock 2 980 Mon Jul 09, 2012 2:34 pm
Mortise lock problem 7 160 Sun Nov 27, 2011 8:10 am
Remove broken mortise lock without key 5 100 Sun Aug 12, 2012 4:33 pm
Fitting lock on to old fashioned mortise doorknob 3 100 Sun Jun 22, 2014 6:29 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
