Hi All,
We have an unvented central heating system (house built in 1996)
Changed a bathroom upstairs radiator on Sunday afternoon. As I had to cut the pipes (to replace 8mm micro bore with 15mm) I partially drained the central heating system by turning the off the stop valve on the small header/expansion tank in the loft and opening a radiator drain valve on a downstairs radiator with a piece of hose attached etc.
Fitted the radiator all OK . To refill the central heating system I just opened the stop valve on the small tank in the loft, as the level dropped the ball cock did it’s job and allowed new water into the system etc.
I bled all the radiators upstairs and downstairs (all upstairs radiators had air in them, downstairs seemed to be ok). Fired up the boiler and turned on the central heating, all radiators including the new one all working OK.
On Sunday evening hot water seemed OK but I guess we were just using the hot water already stored in the hot water cylinder.
Then this morning (Tuesday) no hot water ? all hot water taps are flowing but with cold water. I guess it's an air lock but don't understand how I can introduce air into the hot water system when I was working on the central heating system.
I turned on the boiler for hot water only but after about 45 second the boiler cuts out. Boiler sounds like a kettle and is boiling itself dry ??
The central heating system on the other hand seems fine i.e. boiler does not cut out all radiators are hot.
There are 2 motorised valves in the airing cupboard next to the hot water storage cylinder. I guess one is for hot water and one is for central heating.
I'm not sure what to do next to try and fix etc.
Thanks in advance
Thanks in advance
