DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fire Door between the converted garage to Kitchen
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
Author Message
fais79
from United Kingdom
PostPosted: Tue Oct 06, 2009 3:31 pm Reply with quote
Hello,
I have purchased a house which had the garage converted into a utility room. The inspector visited from the Council and said he wants a fire door to be fitted and remove the current door.
My question is do I need to get a new frame fitted as well or will the existing door frame be ok?
My second question is related to the loft.. The loft was converted into a room without complying with building regs therefore, inspector has mentioned in the letter that the ceiling lining plasterboards need to be removed. Does he mean only the plasterboards on the ceiling should be removed and the plasterboards on the sides can stay?
Many Thanks.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1230 times
PostPosted: Tue Oct 06, 2009 4:55 pm Reply with quote
If the existing frame is equipped with a groove to receive intumescent strips and is obviously rebated to accept a 44mm thick door then fill ya boots.
You will also need to fit an auto closer to the door also.
Why though does he want a f/d? icon_confused.gif
The b.c. needs to clarify why he wants the boards removing and where. He obviously would like to take a peek at the insulation and venting but this will apply to the rafters and (gable?) walls.
He may want a look at the floor joists too.
Back to top
 Alert Moderators
fais79
from United Kingdom
PostPosted: Tue Oct 06, 2009 5:58 pm Reply with quote
Thanks for your advice.
Does the fire door come with intumescent strips pre fitted or does it require fitting separately? I don't think the frame has the the groves. Can they be made? obviously then there is whether it will accept 44mm thick door.
With regards to the loft and utility room the inspector said they cannot look like habbitable rooms. Therefore, he enforced the Fire door for utility room and removal of plasterboards from loft.
But like you said why does he want fire door?? No idea!!
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Tue Oct 06, 2009 7:01 pm Reply with quote
A fire door would not normally be required on a utility room. Why does he want one fitted?
Remind him that you can no longer park the car next to the washing machine
Back to top
 Alert Moderators
fais79
from United Kingdom
PostPosted: Tue Oct 06, 2009 9:58 pm Reply with quote
It's too small to get the car in anyway
Back to top
 Alert Moderators
hotrod
from United Kingdom
Thanked: 110 times
PostPosted: Tue Oct 06, 2009 11:39 pm Reply with quote
In that case, unless there is a highly unusual/unlikely fire compartment or escape route that we are unaware of there is no requirement from a BRegs POV for an FD.
As Woods says, challenge the BCO.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
change converted flat door to open out 2 160 Sun Oct 17, 2010 8:31 pm
Loft converted to storage space, but no building regs? 6 180 Fri Mar 08, 2013 9:33 am
Terrace House Converted Into 2 Flats 9 1540 Mon Aug 23, 2010 12:51 am
Converted House in 2 Flats with Deemed Consent How to sell? 10 840 Sun Apr 07, 2013 8:53 am
Door into Garage from Kitchen. Do i need any planning etc? 2 80 Wed Mar 05, 2014 1:26 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
