DIYnot
Local | Network
   DIYnot > Forums
Local | Network
whirlpool F 3 fault
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
jimbo7kites
from France
PostPosted: Thu Oct 08, 2009 8:21 pm Reply with quote
please help!!!
i have a whirlpool 6th sense dishwasher, and it itermittantly flashes up F3 as a fault. Also doesn't appear to be draining, or finishing cycle.
Unit is 4/5 years old, and service number is
854298429710
Many thanks
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1005 times
PostPosted: Thu Oct 08, 2009 8:24 pm Reply with quote
Whirlpool Dishwasher Error codes.
F0. 10 flashes. Sensor Break (Only shown in test programme. Not visible to customer).
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
These codes should cover the entire range of Whirlpool dishwashers.
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
If memory serves me right it takes about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled.
Back to top
The following user says thank you to rocks1 for this useful post:
jimbo7kites (8 Oct 2009)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Whirlpool DWF416 fault. 3 920 Wed Jul 26, 2006 11:28 am
Whirlpool AWM323 Fault 3 660 Mon Nov 01, 2004 1:40 pm
whirlpool fride/freezer fault 3 620 Mon Mar 31, 2008 4:08 pm
Whirlpool ADG 7450 - Two Flash Fault 4 1040 Sun Nov 18, 2007 2:02 pm
Whirlpool ADG957 - intermittent fault 6 4880 Tue Sep 05, 2006 12:58 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
