2 cold radiators
17 Jan 2005
I have 2 cold radiators, 1 up 1 down both furthest from combi boiler, all others work fine. I have tried bleeding but no air comes out. I have thermostats on one end and another valve on the other side, what is this for, can I fix this? I have no plumbing experience. :( :confused:
other valve is a locksheild used to balance the system
try turning the hot ones down
or it could well be the trvs are stuck closed ;)
thanks for that quick reply, should I not touch the lockshield? should they be open or closed?
thanks Kevplum, both rads are now working, the thermostats were stuck in the off position. thanks to you I have saved a couple of quid and I feel great having fixed it myself.
